Real OU-Effect to Share with everyone!!!
Started by Magnethos, February 02, 2009, 08:37:03 PM
Zigis
Hi NRGFromTheVacuum ,
your experiment is really very interesting!
I certainly want to try it one day, good coil needed first.
I have few questions.
If I see correctly in your videos, you use both bifilar windings in parallel, this give you smallest resistance, any other benefit from this in your setup ?
Did you try connect windings in Tesla bifilar coil - first winding's end connected to second winding's beginning. This increase resistance from 4 ohm to 8 ohm (not good, if I understand right), but maybe increase output voltage?
Can I use 10mm diam ferrite from AM radio antena for coil? preferable turns, wire diam. ?
I see this process as two steps - in first step source voltage loud coil (right end of coil during both switches connected to ground), second step - coil loud back to cap. Wen both switches are on, cap is totally shorted. In my understanding, switch S1 must be connected little longer than S2, then cap is unshorted and can receive impulse from coil. Of course we are talking here about very short times. Maybe your best results is in moments, wen your "switch" is not perfectly synchronic?
Or it work in different way ?
Anyway, if this effect is really OU, it is relatively easy to make really useful machine from this.
Regards, Zigis.
scotty1
Hi guy's.
Sorry I didn't drop in this week...been very busy.
I still don't understand why no more people have made tests....it's not hard?
All talking can do nothing.
I had read a certain experiment hundreds of times and had in my mind how it ought to be, but when I actually got around to doing the test the result was much different than I had predicted and I learn't alot that day that was new to me.
Scotty.
NRGFromTheVacuum
Quote from: scotty1 on March 07, 2009, 07:40:17 PM
Hi guy's.
Scotty.
Scotty,
If you desire to to get a greater result, try making & breaking the connections on a brass plate on top of the coil.
NRGFromTheVacuum
Quote from: PaulLowrance on March 07, 2009, 06:46:34 PM
All of this talk still doesn't answer any of the important questions. I'm guessing you don't have access to the capacitor meter for your experiments. That's fine, and in fact for this case it's better to do the capacitance measurement with a simple RC time constant test. The RC time constant test does not require the cap to be first discharged before taking the test. In fact, you could use whatever charge happens to be on the cap to do the RC test.
If you could please do a quick RC test on both caps immediately before and after your experiment then that would help a lot.
If it's still a thumbs up, then all I can say is to build another bifilar coil and see if it works. If it were me, I would use other caps on the original bifilar coil before building another just to make sure it's not something special with the cap.
PL
Paul,
You are correct, I do not have worthy meters for this experiment right now. I preformed the RCTC tests and used a Craftsman DMM to time the decay. IMO, the results are flawed until I acquire higher impedance resistors, or the proper meter.
The RCTC test for the 30uF capacitor was done directly after the experiment.
The RCTC test for the 7500uF capacitor was done moments before the experiment.
Shanjaq
When Bifilar is implied, the relative winding direction must be specified:  Are the two wires connected in parallel opposition(maximum capacitance, minimum inductive impedance) or are they in parallel co-linear(minimum ohmic resistance, maximum diverging flux density)?
