Real OU-Effect to Share with everyone!!!
Started by Magnethos, February 02, 2009, 08:37:03 PM
newton2
Hello Honoured Profiles and the Honoured Administrator of This The Honourable OU-Forum !
Thanks about the suggested OU-Ideas-Method in Topic (Page 1) ;
THOUGH I AM NOT TRYING TO DE-COURAGE ABOUT VARIOUS SUGGESTED OU-IDEAS-METHODS ,
FOR I SELF DO INTEND TO EN-COURAGE ABOUT RESEARCHINGS IN OU-METHODS ;
THUS I WILL NOT FURTHER INTERFERE TO THE "GOOD-MOODS"-REPLIES-CONTINUED-GOING-ON-DISCUSSIONS "here" per my "formal" Replies "pointes".........
THOUGH OF COURSE SUCH DISCUSSIONS HAVE TO BE MADE OF VARIOUS POSSIBILITIES OF EVEN SUCH AN ELEMENTARY CIRCUIT AS SUGGESTED IN THE INTERESTING ORIGINAL TOPIC (PAGE 1)....................
so just this brief kind hinting Comment :
##The interesting for some further quite otherwise OU-Circumstances-Investigations suggested OU-Method in Topic (Page 1) is basical about THIS Functional Circumstance :
MIGHT SOMEHOW A "CONNECTIVE BREAK" INTO A GOING-ON LC-self-resonances-Circuit
"get" an UN-expected FAR-OF-MORE-Voltage-Built-Up-in-The-C-Condenser
than else per the Max-plus/Minus-Peaks-LC-Resonances-Voltages-in-condenser !!
Well-then.....
==>>TO CALCULATE "FREELY" on UN-specified NON-resistive-having ONLY-LC-resonances
actings
==>>TO CALCULATE ON THE SOCALLED "H-flux-in-through-a-Self-inductance´s-Windings-Inner-areas"-"EMFs"-of-"Time" -->> TO SAY : if suddenly "released" per a "sudden" Connective-BREAK
would THEN the PRESENT-TIME´s-H-flux-in-through-windings-in-SelfInductance could "yeild" a total "Equivalent" CHARGE-in-Condenser "seemingly"-having "MORE-or-LESS" compared to steady-going-on-LC-resonances-up/down-charging of Condenser.....!!
IF JUST A REGULAR COIL OF ONE "IN-SERIES-WOUND-LAYERS-Turns"-Topology is "used" , and IF "USED" is a regular Condenser of "NONE MEMORY-EFFECTS" nor "A-typical epsilon-r-layers" nor "NON-typical-Plates-topologies".....
THEN THE DIS-CONNECTION "FORMS" a fairly-low-impedant-arcings-sparking-"path"-in-Air.....though the PRESENT-TIME-L-selfinductance´s "H-flux-in-through-Turns-"-built-up-"UxI"-Works-Integral THEN just IS the Present-Time-for-DISconnection-being TOGETHER with the Present-time-being Condenser´s "Plate Charges-Voltage" JUST TOTALLING SUMMING UP TO A VOLTAGE being dependent of the Present Time´s Total UxI-products ==>> NOT as suggested in the Original interesting Topic´s (Page 1)´s Ideas-Method:"sudden" MUCH-more-VOLTAGES-building-ups in Condenser because of "DISconnections-Break" !!
(Kind Hint about : the Manually done "work" for to DISconnect in-Itself does NOT "do" a "Work" INTO the LC-Resonances for to should could "make" a sudden-more-per-DISconnection-"yeilded"-MUCH-MORE-Voltages-on-Condenser....for JUDST a transfer of DISconnections-SelfInductance´s SELF-H-flux-to-Turns-Charge-Equivalent as TRANSFERED to the condenser´s Charge "VERY SUDDENLY FAST BECAUSE OF DISconnection....!!)
==>> THOUGH A QUITE OTHWERWISE CIRCUMSTANCE IF THEN INCLUDED-"SOME"
ABOUT" L-MUTUAL-Separate-Windings ALSO is most briefly mentioned in THe Original Topic (Page 1) AND THEN : if L-more windings-mutualities are "about"/being also "present", then with kind formal References to Technics of socalled SwitchMode-Layouts/Designs with TRANSFORMERS !!
WKR & thanks about this re-freshments-of-Basical-Electro-Technics/Electronics-Theses-Topics-Ideas-Method & have Yourselves a nice Day and many interesting Discussions about such Electrical Networks in Aspects also of otherwise Circumstances than intended OU-actions !
And my Thanks about Your All Participations in The Honourable Course of OU  !
For You All do a needed hardlabored Deed for to gain more Knowledges to Mankind !
Magnethos
@Koen1
Yes, performing a fast-switching we can collect "extra" energy, from the vacuum. The theory I know is, when we switch very fast, there is only pure potential (voltage) on the circuit. Current needs some time to saturate the circuit, but voltage appears in the circuit at an infinite speed. So, if we switch fast, then pure voltage is in the circuit and that pure voltage "activates" the circuit and that activation produces a Negentropy process (extracting energy from the local vacuum).
If we switch slowly, current saturates the circuit and then the effect is not possible. The part I don't understand is why NRG can get that effect using copper wire. In copper, the relaxation time is extremely fast (0.00000000000000000015 secs), so that means in 0.000000000000000000015 secs current saturates the circuit. So, in theory, the effect would not be possible. But NRG and Armakuni demonstrates that the effect is possible using copper wire as a conductor. I don't understand that part, because I thought that we need Al-Fe wire, but... not. Using copper we can also get the same effect. I don't understand why. Maybe NRG can explains us a bit about this.
In theory, the energy that we store in the caps using this technique is the Radiant electricity (also known as cold, negative, etc...) but I think we can run the devices using that uncommon kind of energy.
Maybe the key is in the bifilar coil? Some modification in the bifilar coil affects to the relaxation time constant? I don't know..
I have heard something about breaking the local symmetry. I remember that I discussed in other thread a theory about symmetry and energy. And the final idea was, the energy is an assymetrical parameter or something similar, I don't remember exactly. But NRG has shown something about the "negative energy spikes". If you look at his last picture of the scope, you can see the picture is inversed.
He explains that the energy coming from the battery and the energy we collect in the caps are different. The energy we use from the batteries is "common electricity" that generates heat, produces entropy (energy scattering due to a disorded of the information/potential) and exhibits a positive curve in gravity.
The energy we collect in the caps is other kind of energy. That energy is known as radiant energy, cold electricity, negative electricity, etc... it is known by a lot of names. This energy produces negative entropy (information order, energy absorbtion from the vacuum), and exhibits a negative curve in gravity.
I think this energy is also known as longitudinal electricity, and it has different properties. A positive resistances is a negative resistance, it runs on high voltage low current, etc... I'm not sure about this, but If anyone can correct this, correct it.
I read somewhere that Tesla used a special bifilar coil to Inhibit the current. So, Tesla can draw pure potential using his special bifilar coil, instead using the fast switch technique. But both techniques are ok.
About the fast-switch circuit I can post the original one. But the original one needs a 9 Volt battery and the ouput is Square Wave, 30 KHz, Positive offset, 7 or 8 Volts. So, it needs some modifications, but you can get an idea to build your own frequency generator, automatic switch... call it as you want.
http://keelynet.com/biology/zapper.htm
NOTE: You need to modify the circuit to adadt it to your project. But I think if you modify the circuit you can get an automatic and very fast switch. But if you have a better device, then post it. I remember ZeroPoint in youtube posted a circuit to get pure potential from the battery. He deleted the videos, but I have a copy of each video in my hard disk. He said me something about the 555 IC, and the hulda clark need the 555 too. So... I think the Hulda Clark zapper can work (with some modifications)
Frederic2k1
Quote from: NRGFromTheVacuum on February 17, 2009, 06:58:19 PM
Hi everyone,
I thought this picture was interesting because it shows both the input spike from the battery/capacitor and the input spike from the local vacuum.
The oscilloscope is set to 5 volts per division at 250ms.
@ NRGFromTheVacuum
The blue-marked 200 volts could also be the bemf of the coil or am I confounding things here ?
alan
Is the scopeshot measured over the output cap?
I believe what innovationstation did whit his neo zapper was a similar accomplishment: he used neodymium magnets instead of the plate, but he never put in a known energy quantity.
Magnethos
Here you have the videos I talked about.
http://www.mediafire.com/?oe2gojocmdz
A guy from the youtube shows how to get pure voltage using a circuit.
NOTE: The original videos are deleted in youtube. But I made a copy before.  ;D
Maybe someone will have an idea to merge the NRGfromthevacuum circuit and the circuit on the video. The idea is the circuit of these videos shows how anyone can get pure voltage from a battery (withouth switching???). Then we can use this circuit and the NRGfromthevacuum to draw pure potential (Voltage) throught the circuit and then amplify the energy and charge the caps using the NRG circuit.
