Real OU-Effect to Share with everyone!!!
Started by Magnethos, February 02, 2009, 08:37:03 PM
Magnethos
Quote from: fritz on February 18, 2009, 12:07:25 PM
Dear Overunity Seekers !
Maybe nobody wants to realize it - but capacitors - like any other electrical components - and everything else on earth - are not perfect.
If you shorten an almost empty battery - you see how the voltage recovers after removing the short-circuit bridge.
Why ?
Because the battery acts as an infinite amount of elementary batteries - which are partly dead (if empty) or not - which can be seen from the outside that the "internal resistance" - thats an "ideal" approach increases.
BTW its really very difficult to discharge a battery to almost "0" - unless u shorten it for a very long periode.
Similar issues apply to most of capacitors - in higher or lower degreee.
HV caps are well known for these effects.
If you short-circuit them - they are not empty. Internal charge arranges in a way that there is no voltage at the connections.
Its like a bottle with some liquid you cannot empty completly.
BTW: Discharged is not the "lowest" internal energy state of these caps. They tend to increase their "outside" voltage to achieve internal lowest energy state again.
Well short circuit again - same thing - can do that ad infinitum.
This is even supported by the very low leakage current of HV caps.
People who design high precision integrators for very sensible equippement know that.
There are some types of caps which shows very less of that effect - mks types for example.
Now you can flame me to death.
rgds.
I have a personal theory similar to your theory. I think a battery is itself a free energy generator. A battery doesn't produces energy. A battery gets energy from the local vacuum and draws it to everywhere (motor, circuit, light bulb...).
I think amperage is not the amount of energy that pass throught a device. I think amperage is like a gate. When the gate is opened the battery can get energy from the vacuum.
In theory, in a perfect superconductor we would only need pure voltage. But the conductors we use (mainly copper wire) are SEMIconductors. That means there is a resistance. When the current saturates the circuit, that resistance decreases the "amperage" of the battery.
I don't know if I you understand my theory...
T. Bearden says that when we draw current, we are closing the bipolar gate. Maybe when the battery is full, there is an assymetry somewhere in the battery, and while that assymetry is present, we can draw energy. When we have drawn too much energy, the amperage is 0 and the bipolar gate is closed and the poles are symmetric and we can't get more power from the battery. When we 'recharge' a battery, we aren't sending electrons to the battery. We are de-symmetricaling the poles. I mean, turning the poles from symetric to assymetric. Then, we have opened the bipolar gate again (recharged) the battery.
In this thread we're trying to explain that when we connect the source to a resistance, the voltage appears instantly in the circuit, but current needs some time to appear. So, if we switch on/off very fast, we have only extracted pure voltage from the battery. We haven't extracted current. So, the battery is full forever (in theory, because in years the battery discharges). Then, the battery can recharge itself the potential (voltage) again. In this case, we don't extract current, because we're only extracting pure voltage. So the semi-conductor acts like a superconductor because there isn't resistance in that 1 msec.
If we don't draw current from the battery, we can extract all the potential we want forever, because the battery can recharge itself the potential, but not the current.
The energy extracted from that battery (pure potential) have different properties in the circuits: a positive resistor is a negative resistor, the battery acts like a diode, etc... There are 'Negative Properties' in the circuit components.
I read somewhere that there are 4 kinds of electric current. We use the 'electron current', and we need to use 'ionic current' if we don't want to discharge a battery. When we draw current we are turning some factor in symmetric. A full charged battery has some kind of broken symmetry or something similar. So, I think in all the cases we're drawing voltage. But in the common systems we can meause the 'amperes', but in reallity we aren't measuring the electron flow. We are measuring the speed we're turning the battery from assymetric to symetric. Of course, current appears when there is resistance, because in a perfect superconductor we can't measure the amperage because there isn't resistance. In a perfect superconductor, we can run any device using only pure voltage. But in the common semi-conductors, there is an opposition to the pass of the electricity and that opposition is the factor that discharges (assymetric to symmetric) the battery.
A battery is also called a Dipole, and each dipole has north and south pole. A magnet is a free energy device, batteries are also a free energy devices. The only reason why we cannot get energy from magnets is because they have equal strengths at the poles. Without a difference in potential, work can not be done.
Leedskalnin shown that we can re-configure the magnetism of a magnet to get energy from a motionless magnet. So, I think the amperage is a magnetic property (remember that ALL is magnetic, but much less than ferromagnetism). When there is a difference in the strengths of the poles, there is assymetry and then we can extract electromagnetic energy. But if we connect for a high amount of time the battery, then the battery discharges. The time current needs to appear in the circuit is some femtoseconds. If we switch on/off very fast, then we have extracted pure voltage and the assymetry of the battery is the same (bipolar gate opened). If we maintain the battery connected for a while, then current appears and we're killing the bipolar gate because we're turning to symmetric the poles.
I know there are techniques to inhibit the current and I know Tesla did something about that.
Maybe the link I posted some posts before, it's a good Current Inhibitor device. If we don't draw current, then we will have a free energy device. Look at the batteries like a Vacuum to Electromagnetic Energy transducers, not like a piece that contains electrons.
I hope someone understand this theory,  ;D
CTG Labs
Hi NRG,
The math looks good!  Can I ask though, and sorry if this has already been covered, you are quoting the printed capacitance values and of course they will have a manufacturing tolerance which could throw all the calculations off.  Have you measured the actual capacitance of each capacitor with a capacitance meter or perhaps used a known resistance and timed discharge method?
Thanks,
Dave.
fritz
Attached some schematic on the composition of a "real" cap containing infinite amount of elementary caps with a series resistor Rs, a parallel resistor Rp and a parasitic coupling capacitor Ck.
If you have a serious amount of C elementary with high Rs - they can even be charged spontaneous thru Ck - but are quite difficult to discharge because of high Rs.
Thats no theory. Just look into standard literature.
Unused HV caps should be stored short-circuit because of that effect.
Because they can "recharge" by this effect - and that can be dangerous if you operate / mount them.
rgds.
Magnethos
here are discussing about orthodox science and 'alternative' science. Until know, we haven't built any succesfull free energy generator. Maybe because we're using wrong theories, or we aren't using the theories we must to use. We can think un-thinkable theories if we want to achieve un-thinkable things.
fritz
I wouldn´t trust any cap - which is "more" than a medium sized plate capacitor.
As long as the operating frequency is low - an elctrical shielded plate capacitor (preferable with vaccum as dielectric) should operate almost like an "ideal" cap.
Everything else has Rs, Rp, Ck.
Thats why "professional" RLC meters measure at least Rs and Rp.
If we need overunity to explain the behaviour of an HV cap - than we are far out anyway.
