simple free-energy generator
Started by schmoe, December 30, 2005, 03:53:18 PM
Question:Robert W. Alexander(US3913004),functional ?
You give me the answer,many thanks !
Sincerely
            de Lanca
r8rchris
de, Lanca, I did not build this generator. All I know is what was posted. I can verify that a 3phase motor turned at rated rpm will generate a working voltage. So if the magnets spin it fast enough it will work.
Accepted,no problem !
I did not said that you reproduced this patent or other publications !
You posted also ever "AC"-based,the Alexander-concept is "DC"-based !
I thank you because your configuration-work-out !
Sincerely
            de Lanca
Elvis Oswald
Whatever material you use to shunt the magnetic field, in order to reduce impact on the south pole magnets upon approach would probably require a unique design - since you are not completely surrounding the 'base magnet' - and I'll have to think some more on what they design considerations would have to be.
I'm also thinking that the base magnets would have to be strong... and that would complicate your shunting efforts.
