Bloch Wall Generator
Started by jkgulick, February 05, 2009, 05:05:01 PM
i_ron
Quote from: jadaro2600 on December 07, 2009, 12:31:00 AM
Any developments on this thread?
Well, I can at least say what doesn't work.
An iron core with magnets on each end does not work.
I used an iron core 50mm long by 25mm dia, and 25mm by 6mm magnets.
A 280mm rotor with 24 NSNS magnets around.
Findings:
Just the two 200 turn each, air core coil generates a voltage...4.16 volts
Just a plain iron core generates a voltage....8.1 volts
Core with magnets... 7,15 volts
Conclusions:
The core with the magnets attached generated less wattage than did the plain core. 2.5 watts for the core/magnets versus 3 watts for the plain core.
Lenz was apparent, difficult for me to measure in/out at these small levels but approximately 2.4 watts additional for the prime mover as against 2,5 watts output.
Ron P
The clamp on is measuring .52 amps (120V AC line)
The voltmeter shows 4.34 volts AC
The ammeter shows .6 amps  (2.6 watts)
Mk1
Try to find a old hair clipper the ones with a big coil in it ...
rave154
I-ron.....are you THE "Ron"....that made the new rotor for Thane? ( thought youre work looked familiar)
the only thing i can see in your setup thats different from the diagram......is that you have your coils/magnet combo.....at the side of the rotor....as opposed to the edge of the rotot...as is shown in the diagram........dont know if this would make a difference.....just thought i would point it out
i_ron
Yup, it is I.
That is my "standard' RV test bed but not the Thane rotor in this picture. Changing the drawing to axial should have no effect. What is different from the initial drawing is this is modification from a later post where it was proposed to use a core to separate the magnets.
What I note in the above experiment is the windings can not be directly in line with the rotating magnet as it will generate a potential with the usual lenz reaction.
Anyway, thanks for the comeback
Ron
[/quote]
[/quote]
i_ron
Quote from: i_ron on July 09, 2010, 10:25:02 PM
OK, I did one more experiment with a 1/2 inch by 3 inch magnet and a sniffer coil. Max induction is just outboard of the rotating magnet width but not terribly impressive... .008 volts per turn.
Ron
