Bloch Wall Generator
Started by jkgulick, February 05, 2009, 05:05:01 PM
T-1000
Quote from: garrypm on October 06, 2011, 04:15:14 PM
Thanks T
Just in my setup there's npn transistor but should work with pnp too. With trial and error experience you will find out what works best. The pulsing electromagnet is your analogy to moving magnet in generator and might remind Muller dynamo, just solid state in this case :) Make short pulses as possible just to power L1 (longer impulse time just wastes energy). Also you can try various electromagnet magnetic strengths and can take energy out of coil right after your pulse is off then put into caps over double 1N4007 diode bridge for their lower resistance. With precise timing you should get best results.
Good luck!
