FIRST HOME COLD NUCLEAR FUSION REACTOR ALREADY IN POLAND.
Started by Doctor No, February 05, 2009, 05:14:59 PM
Dr Adolf Nowak
So build it for yourself, why not?                                                  Mr Grigs has really no knowledge about cold nuclear fusion, if fusion generely. He had done sthg by occasion (same was for Potapov). You can clearly read in my bio, that all my inventions and theories were born between 1969 (mein erste Besuch im Berlin) und 1972. I knew that it all had to be studied already for previous War (Krieg) needs. And when than and today, The Science says and knows nothing about gravity......        Gravity (time shifting for various purposes) was main gear for "Star Wars", not lasers and so on, as was said publicity. But works go on, and soon all Humanity will see effects.   DRJ1000.11 can produce compressed steam too. It^s about 100 kG/1H. Atomic reactor with same power can only 1/10 of this volume to produce.      For home heating it needs not to produce steam, hot water only as DRJ200. Between this 2 generations is 7 times efectivity difference. So we need sthg. between it.
pix
Dr No,
What is your point?
Vertical Axis Wind Turbine is known for the ages.
Cavitation pump is also long time known, see Griggs patent for example.
Why you claiming whoaaaaaaa: cold nuclear fusion reactor?
Do not make fool of yourself.
pix
Dr Adolf Nowak
Typische polnische Hure. Wer aber mochtete was mit solche zu machen, frage mich oft? Auf Strassen Strich bessere sind. Und kluger zudem!
pix
mscoffman
@Pix,
This is good thing. I guess Dr. Nowak has trouble communicating due to linguistic
differences.
First, like Stephan said, this is a Griggs Pump unit. You can have a Griggs pump
built in the U.S., but that company won't guarantee its long term performance.
That's the problem. Just heating water mechanically does not need to be an
overunity process. Unless the manufacturer can guarantee that it is an overunity
process, it won't do you/me any good because it will still heat water underunity.
So if you say that "it is not working" and the company will say that "it is working",
because they feel they can't give a written guarantee of overunity performance
without also giving a scientific explanation of how it works.
The Griggs pump heats water partially via cavitation/cold fusion, using natural
deuterium fuel from the feed water. This is cold fusion - a nuclear process.
Inside of the pump the Griggs rotor actually lights up due to plasma cavitation.
Contaminants probably result in the unit not behaving so nicely in the nuclear
regime.
Because of the way this works - it's product is thermal energy gain. So the VAT
wind turbine thing is nothing more than an initial energy source to spin the Griggs
rotor. Then, when the thing heats your entire house you have assurance of energy
gain. :-)
The next problem is guaranteeing that Griggs pump is actually generating overunity
energy because the way they have the demo set up seems to count on running the
same heated fluid thought the pump again and again. So whether it is overunity or
not the heated water will be processed again and again through the accumulator
tank. Therefore, except for the time factor, the water in the accumulator is going
to go through the same set of temperature points whether it's overunity gain or not -
just in different timeframes. Most likely the output is will end up becoming steam.
The way they handle this in Eastern Europe is to add an industrial calculating controller
that measures the difference between input vs output temperature of the pump
per unit time and so they have instrumentation tell them whether it has overunity
heat gain or not, based in calculations. Not exactly a great way to prove anything.
Unless you need hot water, you are going to have the next problem which is
the efficiency of Carnot heat engines is only going to be about 33% or less.
Therefore the Griggs pump gain is going to need 300% gain per pass to compensate
and more passes takes more energy, so having a closed loop to prove anything,
when the output is heat energy is going to be tough.
Because of all these proof problems, the Griggs pump is not my favorite
vehicle for delivering cold fusion energy gain, even though it is an economical
implementation, if it does work. So you need an organization that has the
guts to stand behind a particular explanation of how it works. So over time
they will just get better and better at doing this and showing that it works.
:S:MarkSCoffman
