HHOHHU.com HHO heater. Is it overunity ?
Started by hartiberlin, February 06, 2009, 12:59:24 AM
Robb077
Fran:
Great explanation. You sound like a physicist.  What is the Link to Jovian?
Another great idea is Kim's patent at BrownsGas company in Korea. You can burn brown's gas in a closed ceramic vessel and it turns into a self-sustaining plasma...nearly. Gas input can be turned way down and enormous heat is output.
It helps to understand water is from comets (ice) and comets are trailings of the surface of the sun....fire...that have spun off into outer space. So the fact that water can burn nearly perpetually without exaust is realizing the surface of the sun burns continuously over and over.
Robb
sterlinga
Quote from: hyperhho on March 03, 2009, 02:28:57 AM
Please don´t post copyrighted material over here !
Regards, Stefan. (admin)
I'm not sure what you're calling "copyrighted material".  The material cited is shuff I wrote, which I posted here.
If you're referring to the phrase "HHO", I'm not an attorney, but I can't see how anyone could claim to copyright that term that has been used widely by the international, open community that has been following, tinkering, and developing the technology.
-- Sterling D. Allan
http://freeenergynews.com and http://peswiki.com
"The best cutting-edge, clean energy news and directory service on the net."
pmazz850
woodpecker
Quotefrom froarty: So your easiest experiment is to use heat to disassociate the hydrogen in the same pipe sourcing your flame so use a thick long pipe and heat in the middle in case you have leaks at the connectors and instead of killing yourself trying to create a skeletal catalyst experiment with creating "Casimir gaps" - try sand, lime or conductive powders in the heated tube -crystaline would be best- the facets not only create the gaps which would form the casimir geometry but they also allow the gas to diffuse through - there is a property of hydrogen diffusing though metal lattices to become monatomic naturally such that if you had a crystaline metal powder you might not even need to heat the tubes which is the method Jovian is proposing. Or any other method to make your hydrogen monatomic but this is the other reason this process is so difficult to uncover is that hydrogen wants to immediately drop energy and form a molecule -if you keep it monatomic long enough to enter a casimir cavity they become hydrinos appearing to shrink -if they bond while shrunk they cannot freely grow back to normal when exiting the field and nature has to break the bonds restoring the mon atomic energy levels and rearming them for the next cavity - if you have these cavities adjacent to each other like Jovian you can repeat this procedure over and over turning nature into a hydrino thermal rectifier.
Fran
This is very interesting! Do you have any more information on that? Do you refer to pure Hydrogen? What i am producing with the drycell is Hydroxy.
@Robb077,  i played just around a little bit with the gas, and was putting the flame very close to the surface of a bowl of water, and the interesting thing was, that i got hundreds of very little bangs and one ore two times a bigger one. To me it looked, like the hydrogen in the water was disassociated!?
Some kind like a Plasmareaktion?! Now i imagine, to have a Flame under the water, just strong enough to get such kind of a reaction do produce even more hydrogen and heat.
Do you have any more information about this Korean patent?
woodpecker
hartiberlin
Quote from: sterlinga on March 03, 2009, 06:05:46 PM
User:
hyperhho
had posted the stuff that hhohhu.com sells.
So I removed the links.
Regards, Stefan.(admin)
