ENERGY AMPLIFICATION
0 Members and 161 Guests are viewing this topic.
otto
Hello all,
@Tito
trust me you will again work on your TPU.
The newer versions of the TPU are made in that manner that they can be in an inverted position and work.
Yes, the work on a TPU can sometime be boring for some people but for me its fascinating. Every day a new discovery. Fantastic.
Otto
Tito L. Oracion
Quote from: wattsup on October 01, 2009, 08:46:22 AM
@Tito L. Oracion
OK, thank-you for your kind reply. I understand everything you are saying and it does make sense. Of course it makes more sense for you since you are the maker, but I really do understand the general idea.
Funny you should mention those Tesla patents which are variations that also include the Tesla Ozone Patent No. 568,177. That patent is a prime step that any OUer should know about as a basic method. The only part is the end usage to concentrate the high voltage into lower voltage higher amperage. That is where the battle will be won.
So creating a short (Relay, Switch, Rotary, Transistor, Mosfet - or other) over a DC supply and disconnecting that via one or more high inductance coils, one or more charge capacitors, one or more (series or parallel) working transformers and you can do what Tesla always said did not waste energy, and that is working with damped waves permits you to return most all the energy back to the source. I think that is what you mean by using small energy. You can use small energy at a time, but you can use bigger energy and give most of it back and that consumes the same as the small energy. lol
Meaning, you can run a very small circuit using a battery and consuming only .1 amp at 12 volts and never returning this energy back, or, you can use 12 volts at 4 amps with the Tesla method and put back into the battery 3.9 amps. Both ways you are consuming only 1.2 watts but the second way you are running a much bigger device hence you have a better chance of getting more output. Makes perfect sense.
So I gather by indicating an inverter, your main device output is 12 vdc with good enough amperage to run an inverter and get your 220vac at 5 amps 50hz output. OK sounds logical but only if the 12vdc production is clean and steady otherwise most commercial inverters will go into an automatic shut-down. Hmmmm.
Also, regarding wasting time on the TPUs, in a very big way you are right that it is a waste of time because anyways, we will never be able to prove whatever we make, even if it follows the style of an SM TPU, will be exactly like the original, but again, who cares. Some are close enough and I am also especially working on and learning from the FTPU. But it does not stop us from doing other things in between. lol
Added:
@ronotte
Just saw your post at same time as mine. Hmmmmm.
Good ideas.
I am putting a diagram I made a good while ago that I think is close to what you are saying.
hI SIR GOOD DAY!!!  ;D
BINGO!!!
I intentionally not included that patent because that is where i am is working, your very good sir!  ;D
You always admire me with your post sir , your so kind  and i'm honored being  with you here sir. I also learned a lot from your post sir thank you very much.
i just want you to know that i'm an avid fan of your posts, they realy makes me to think and revised always my works!  ;D
all you've said are absolutely correct!
Tito L. Oracion
Quote from: ronotte on October 01, 2009, 11:15:04 AM
@ Tito,
I apologize for intruding into you thread: of course I am following your very interesting project!
anyway if any problem just let me know as I could create a new thread  (I did not that in order do not create too many threads).
No sir its okay, your very much welcome !  ;D
nutsNbolts
ello Tito
Perhaps you should contack Dr S Greer.   He has the infrastructure set up to see new energy is safely distributed.  That's if you are for real and not cohersing others to do your experiments for you.
http://www.disclose.tv/viewvideo/29990/Dr__Steven_Greer_The_Promise_of_New_Energy/
Tito L. Oracion
Quote from: nutsNbolts on October 03, 2009, 10:19:19 AM
ello Tito
hi sir good day!  ;D
Actually i'm thinking for that but i have to be very carefull of course its like making an experiment you have to consider many things ok.
i am not cohersing others, i want them to discover it themselves, i believe if your a researcher, you can notice if what i'm saying here has sence ok.
i'm telling you and i promise you that my system is very easy to replicate, very easy to do it really change the way we use a source !
i'm repeating what i am is always saying, the secret is in the arrangement of battery, coil, capacitor and diode.
did you realized a tesla switch? how easy and simple to replicate, ron cole even made an inovation for it using only 2 capacitor and 1 battery but still the result is the same ok. the only challenge is how to make a durable switching technique.
do you know that even in hardware store you can make a design of durable switch.
did you try in tesla switch pulsing a coil and feed that to inverter, ofcourse rectify it first!  8)
