ENERGY AMPLIFICATION
0 Members and 38 Guests are viewing this topic.
MasterPlaster
OK Tito, how much money do you want?
Tito L. Oracion
Quote from: eisnad karm on April 14, 2011, 11:28:49 PM
another one bites the dust. We can give this one the 2011 Mylow encouragement award. It comes to put up and shut up time off they go. At best it sounds like he had only a theory.....and it could have brought money to him if he could demonstrate it.
Sadly goes in the category "delusional"
Always happy to be proven wrong and withdraw my opinion.
Kind Regards
Karm
I understand you bro, but as i said i'm telling the truth, and by telling this you will have an idea that it is true, and it is true, theres really a simple way of amplifying a very small energy.
whose that mylow! they always say that, i don't know actually the story of mylow, please tell me, what did he do, i always see his name here.
Hi master plaster
thanx for your money, but i don't want to gamble in this way, i'm using OU just for personal use only. This way i can make money safely, ha!ha!ha!   :)
And i am here just to see if somebody is discovering it ok  ;)
but as of now as what i see, maybe  tariel, SM, and some russian have it.
@ mark dansie
    you know man, i am not forcing you to believe me, i gave a lot of pointers here to study with, for you to discover it also. now if you don't believe, just make the bedini proj ok?  :D
I DON'T CARE!!!!!!
@ ALL
I'M  ALWAYS SAYING AND REPEATING THIS AGAIN: DO YOU THINK TESLA SPEND A LOT OF MONEY BUILDING THE MAGNIFYING TRANSMITTER WITHOUT A POSITIVE RESULT!
IN THE FIRST PLACE: WHAT TESLA IS HIDING PLAN  IS TO POWER THE WORLD USING ONLY ANTENNA RIGHT AND THAT IS JUST A COMMON SENSE RIGHT?
NOW!!! IT WAS DESTROYED BUT HE'S STILL MADE HIS E-CAR RUN USING ONLY ANTENNA, THAT IS BECAUSE IN THAT TIME RADIO STATION SIGNALS BECOME POPULAR AND THEY ARE DISTURBING THE AIR .  8)
NOW! WHY USE SIGNAL IF THERE IS BATTERY? WE CAN USE IT AS A BUFFER RIGHt. THATS IT!
NOW!!!!!! DON'T BELIEVE ME!!!!!! JUST BELIEVE TESLA RIGHT!!!!!
AS I'M SAYING THIS AND AS OF YOU READING THIS, THEN YOU WILL HAVE NOW AN IDEA THAT WHAT I'M SAYING IS TRUE OK!?
IS MILO DELICIOUS?  :D
wattsup
@ALL
I don't know why you guys keep on breathing down @Titos' neck, trying to figure things out.
Just look at what guys are doing now. ONE PRIMARY TO ONE SECONDARY on a toroid or on a core. Produce a strong enough pulse on the primary and gather up the secondary to send back to source as a loop. But it does not work for OU. Even the Joule Thief guys are making the same MISTAKE. One toroid only will not cut it.
It is the configuration and not the lack of reaching any resonance mode. Instead of using one toroid, USE TWO, THREE or MORE toroids with the primaries either in series or parallel. With the secondaries then in parallel you will have more amperage output.
If your car runs badly with only one tire, you put four tires and bingo you are on a roll. Even an electric motor has more then one winding to run.
The Primary is usually the fattest wire having the least resistance. Right or wrong. So putting two or more Primaries in series will not change the resistance to any great level permitting the input pulse to hit several primaries with one pulse.
Some will then say if you put four primaries in series, each one will only be able to transfer 25% of the impulse to the secondary. But what if this is wrong. What if each primary can transfer 35% or more. That's one place to start right there.
But instead, guys are adamant that IT MUST WORK WITH ONLY ONE TOROID OR ONE CORE.
The other thing is how to accumulate the secondary without having the same secondary create a backlog in the primary. There you need a proper choice of tank capacitors. Not to low an mF to backlog quickly, but not to high an mF to have a fast enough discharge back to source.
wattsup
Tito L. Oracion
YOU'RE RIGHT SIR!  :)
@ ALL
DON'T BREATH ON MY NECK CO'Z YOU ALMOST KISSING ME :D AND SOMEBODY IS BAD BREATH!  >:(
JUST THINK AND THINK DON'T PUNISH YOUR SELF FIGURING WHAT I'M TALKING. I JUST SAID THAT FOR YOU TO HAVE AN IDEA AND ENCOURAGEMENT OK  ;)
forest
I'm still fighting with the problem of choosing : what is better ? : many primaries in series or many primaries in parallel ? Which would work ?
