ENERGY AMPLIFICATION
0 Members and 58 Guests are viewing this topic.
forest
Quote from: Tito L. Oracion on October 04, 2009, 02:21:36 AM
hi sir good day!  ;D
Actually i'm thinking for that but i have to be very carefull of course its like making an experiment you have to consider many things ok.
i am not cohersing others, i want them to discover it themselves, i believe if your a researcher, you can notice if what i'm saying here has sence ok.
i'm telling you and i promise you that my system is very easy to replicate, very easy to do it really change the way we use a source !
i'm repeating what i am is always saying, the secret is in the arrangement of battery, coil, capacitor and diode.
did you realized a tesla switch? how easy and simple to replicate, ron cole even made an inovation for it using only 2 capacitor and 1 battery but still the result is the same ok. the only challenge is how to make a durable switching technique.
do you know that even in hardware store you can make a design of durable switch.
did you try in tesla switch pulsing a coil and feed that to inverter, ofcourse rectify it first!  8)
@Tito
Is your capacitor unconnected from power source during disruptive discharge and energy is recovered later or you found a way to sent part of energy not used back to power source directly while discharging capacitor ?
Lately I discovered something what Tesla surely realized when he was observing discharge from Edison HV DC generators ,when they were quickly powered on. All I need is information about radiant energy event which occurred when DC generators where switched on - was that a rare accident or very common ? 100% reproducible or rather random ?
Tito L. Oracion
Quote from: forest on October 04, 2009, 08:14:17 AM
@Tito
BIG YES THAT IS 100% REPRODUCIBLE!.
Sorry i do not want to answer you in detail but your very near  ;D
Capturing radiant energy is easy, i beleive you can solve that.
be carefull sir because many died in that incident.
onthecuttingedge2005
The best way to store electrons is not by capacitor or batteries, it is by superconductors, neither could compare.
Using superconductors to capture and store the decay energy of Beta emitters is so far the safest civilian nuclear and would be very highly efficient, depending on the nuclear Isotope one could run for a decade or even hundreds or even thousands of years before it needed the isotope replaced, using Tritium the cell would stay charged for 12.3 years before half of the nuclear material needed to be replaced. if you are interested I could build a Beta decay Isotope list specifically for this purpose. but unless people are really interested I would be wasting my time.
lose not, waste not.
Jerry 8)
forest
Tito
So you are using high self-inductance coil to cut power source connection while capacitor is doing disruptive discharge into working circuit, meaning that in this step energy is not lost by heating power source battery.
That is I think what Tesla realized after seeing radiant energy discharge and investigating it. Quenching circuit which allows unidirectional discharge of capacitor (still oscillating but that another story). In case of Edison DC generators it was due to badly constructed commutator with dead spot which quenched discharge at spark gap (=power switch).
I yet have to find Edison patent to confirm that and also chronology of improvements. The most useful would be to know the list of issues that Tesla had to improve in Edison generators.
This is how I see it :
if electrical energy is condensed  and pumped into wire it has momentum.It is vibrating while flowing on inductance. If suddenly there is a gap in flow then it tries to return back. If return path exits that energy is dissipated by heat and light and other range EM radiation.
If return path is disconnected in correct timing energy has to be released into envinronment but it can't produce much electric field,due to missing back rush path - no EM radiation is possible or only a little.Energy is then radiated as ripple on magnetic field surrounding wires and further into ambient field, because stopped oscillation in every case has to release energy. I think we are near to find complete new science area of longitudinal magnetic waves.I'm not arrogant to state that only one kind of such phenomena is possible. I rather think it's a bunch of phenomena ,complete new spectrum of frequencies and waves.
Sorry,I tend to chatter...
Tito L. Oracion
Quote from: onthecuttingedge2005 on October 08, 2009, 02:56:45 AM
Jerry 8)
Hi jerry good day!
this is new to me sir, i am interested  ;D
and this is great!!!
will you please demonstrate more sir.
