ENERGY AMPLIFICATION
0 Members and 73 Guests are viewing this topic.
Tito L. Oracion
Quote from: ramset on May 04, 2011, 08:28:05 PM
Ð'лагодаря за всичко на коеÑ,о ме научи. Поклон пред Ñ,еб.
Translation
Tito Why are you so Ugly,and you smell Bad!
And this  :o :o :o :o
That means  "Yes you hurt my eyes"
Chet
hahahahahahahahah lol  ;D
thank you  ;)
Staffman
@Tito
Translated Via Google Translate (Bulgarian)
Thanks for everything you taught me. Bow to you
@Ramset
:D :D :D
Tito L. Oracion
Quote from: Staffman on May 04, 2011, 08:33:54 PM
@Tito
@Ramset
:D :D :D
i'm confused which is telling the truth? really? please.  :)
Sir wattsup whose telling the truth?, i trust you anything you say.
ramset
Tito
I cannot tell a lie [well sometimes?]
I lied
I don't know what it said!
Chet
Thanks Grandma
Bruce_TPU
Hi all,
I'm off in TPU land working very hard, but figured most of Tito's stuff out after the last set of pics he posted.  I wrote him and asked if I could post it.  He said yes, and added a bit more information.  I am too consumed to build this or the gravity machine, but seems pretty easy.
Basically, he is using a cascade voltage multiplier to up his voltage, dumping it into a bank of caps, using a fancy switching system to discharge each cap sequentially, then taking all of that combined voltage from all of the caps, and running it through his diode bridge configuration to change some of it back into amperage.  He is then ending up with more out then in.
Not too sure where or if a coil fits in, he would have to answer that.
That's it.  I hope that helps someone!
Back to rotating magnetic field...lol
Cheers,
Bruce
