ENERGY AMPLIFICATION
Bruce_TPU
Quote from: Bruce_TPU on May 04, 2011, 09:53:56 PM
Hi all,
I'm off in TPU land working very hard, but figured most of Tito's stuff out after the last set of pics he posted.  I wrote him and asked if I could post it.  He said yes, and added a bit more information.  I am too consumed to build this or the gravity machine, but seems pretty easy.
Basically, he is using a cascade voltage multiplier to up his voltage, dumping it into a bank of caps, using a fancy switching system to discharge each cap sequentially, then taking all of that combined voltage from all of the caps, and running it through his diode bridge configuration to change some of it back into amperage.  He is then ending up with more out then in.
Not too sure where or if a coil fits in, he would have to answer that.
That's it.  I hope that helps someone!
Back to rotating magnetic field...lol
Cheers,
Bruce
Hi forest and company,
Did you all read this?
Cheers,
Bruce
forest
Quote from: Bruce_TPU on May 05, 2011, 05:06:36 PM
Cheers,
Bruce
Yes,it's quite possible but it's just one of possible ways. Capacitive. I don't know how he converts voltage from caps into amperage or it's just happening ? That's what still bothering me : how to dump many HV kicks into large cap or caps and retrieve lower voltage but higher amperage.
Bruce_TPU
Quote from: forest on May 05, 2011, 06:41:40 PM
Hi forest,
Go back to the pictures he posted, of the caps, diodes, etc.  One was a type of Diodes in parallel that convert high voltage to amperage, or so it says.
Oh, and one more thing, if he dumps say 300 volts and the caps are all in parallel all of the voltage is the same across the caps, 300 volts.  Now if you sequentially release with a high speed switching system, one at a time, and say there are three caps, you will end up with 900 volts.  I think that is the jist of it.  Then turn that 900 volts into amperage.
Cheers,
Bruce
Cheers,
Bruce
wattsup
Quote from: Bruce_TPU on May 05, 2011, 08:46:02 PM
Hi forest,
Cheers,
Bruce
Cheers,
Bruce
@Bruce_TPU
Geez that sounds a little like the Voltage Grabber animation I made a little while back.
http://purco.qc.ca/ftp/Wattsups%27%20stuff/voltage-grabber-circuit-VGC/
Just click on the gif file.
wattsup
Bruce_TPU
Quote from: wattsup on May 05, 2011, 11:19:13 PM
@Bruce_TPU
wattsup
Very cool Wattsup.  I think the that is kind of it.  Pretty simple in theory, but would take some folks with decent electronics skills to develop a switching circuit.
Tito already did.
I have helped these guys out, with confirmation from Tito, so I'm back to TPU land, very focused on my own experiments at the moment.
Cheers, and happy switching!
Bruce
