ENERGY AMPLIFICATION
0 Members and 97 Guests are viewing this topic.
gsmsslsb
Quote from: forest on October 15, 2009, 02:48:26 PM
can you charge capacitor faster then current can flow inside ? like Bearden said - by using only potential to realign the rest of electrons which are there for sure
how ?
is there a method of charging capacitor which is faster then relaxation time ? how we can charge capacitor with very short and rapidly changing voltage spike to full capacity in short time ? can we convert HV spike into constant current just inside capacitor ? what is equal to charging capacitor with constant current for infinite time while being a finite short time action?
After reading teslas ozone patent I think that may be what is happening.
He is using the spike from the colapsing field in thr motor windings and the coil to chage the cap.
then he dumps that from the cap through the primary of the coil.
Maybe this is what Tito L Oracion is doing.
That way you can just stack them up as many times as you need to with each cap dumping into a coil and collecting the spike in another cap.
MasterPlaster
Maybe the trick is in the dielectric.
forest
http://www.youtube.com/user/NRGFromTheVacuum#p/u/10/2cUS03yNl40
maybe the trick is to charge capacitor with very fast voltage spike across changing in time resistance which depends on voltage
MasterPlaster
Ok forest. I saw this video over a year ago but I did not give it much credibility yet you seem so sure. I just bought some huge capacitors. If it is so easy, we shall all be having free electricity by Xmas!
samedsoft
Quote from: forest on October 16, 2009, 06:37:52 AM
Can you use same capacitor on both sides. And start with with one cap at 24 V?
After you charge other one to 200 Volts you can show on camera.. Then you discharge charged cap to 0 and do it again...
