ENERGY AMPLIFICATION
0 Members and 71 Guests are viewing this topic.
TheCell
The battery having 2*U , the parallel caps having initially U, connecting them to the battery an energy delta Wd = C * 3 U^2 is fed into them. (C is the capacity of one cap)
Putting them in series , will not change anything in the energy-level of the caps.
Connecting the series caps to the battery the same energy delta   Wd = C * 3 U^2 is fed back into the battery. No Energy gain.
But when you get the lead acid battery to resonate , it's drawing energy from the ambient. Put a few diodes in between, so the caps are only connected when there is a voltage difference, so a dipole can be established after the current flow. YT Vid Inquorate_tesla switch bedini hybrid.
See the ringing. This is the effect.
forest
or you can discharge via coil
Qwert
[/quote
Quote from: Tito L. Oracion on November 22, 2011, 11:24:08 PM
Suppose...
...Now only one method is missing  ;)
Tito, you can speak (write) fluent English recently... or rather you use the copy-and-paste method here. What is the source of this citation?
Magluvin
Quote from: forest on November 23, 2011, 05:18:28 PM
Hey Forest
when your saying discharging with a coil, do you mean  the primary of a transformer to get usable output while charging the caps, and during series charging while dumping the caps to the batt?
Otherwise I dont see it.  ;]
I think I was close to this idea before. I have to look back at my stuff.  ;] lotsa stuff =[
Mags
Goat
Hey Mags;
I think this might be a help to you and all, it's regarding charging capacitors in parallel and discharging them in series using spark gaps.
Sorry if this was already brought up but it seems relevant to the conversation and might be worth repeating.
http://encyclopedia2.thefreedictionary.com/Pulse+Engineering,+High-Voltage
Regards,
Paul
