ENERGY AMPLIFICATION
0 Members and 114 Guests are viewing this topic.
forest
oouch ! so we have higher wave amplitude (voltage), higher frequency (wave bouncing) which also means higher amperage (because amps is charge moving in time, speed up them and you rise amps) - IF that effect can move small current (bounce it along with voltage wave) sent from primary to the secondary by Tesla method or resonance
And that all for free for some time up to the ringdown of bouncing of the secondary ? it look weird  :o it look impossible , crazy ! am I going nuts ?
Magluvin
Forest
I feel where you are coming from, but if his "way" can take advantage of a small, simple generator charge, and have no battery, that would be a nice little project sitting on the table to show proof of concept.
If it doesnt take anything from the battery, then it wont take anything from the generator either, and if the output is good, we could run the bedini (efficient) to drive the generator that has no load. OU, isnt it? A little vicious circle.
Its just easier and cheaper to experiment small.
Magluvin
forest
It takes from battery but you can minimalize amount of power taken  IMHO  Because output power can be huge you can divert part of it back to close the loop and remove battery. Isn't that simpler then using Bedini wheel ? Look at Kapanadze device or Willis magnacoaster. The goal is to have battery only as a starter.
Magluvin
That is fine. Lets say I just give it a spin, without a battery to start, that would be good also.
Magluvin
Magluvin
Not that I know what Tito is actually doing to get his setup going, but I see caps in series with coils, and I hear Tesla saying pulse the coil with a charged cap.
I have tried some experiments with a coil being induced buy a rotor with magnets and using caps in series with it to induce voltage across another coil that isnt near the rotor. Then I use a reed to pulse the second coil and taking the bemf from that to charge another cap. The rotor driven coil has much less drag on it compared to without the caps and Im still getting some high voltages to my final cap. I am trying things.
But Tito-wan-kenobe is our only hope!  Thus far. =]
Magluvin
