ENERGY AMPLIFICATION
0 Members and 140 Guests are viewing this topic.
light2011
Hello to everybody !!! :)
i hope is not off-topic, but I find some interesting similarity between Tito's drawing and my old book - Radio TV guide / 1987.
similarity with tito's doc1_1.JPG = may be JT, in fact is autobloking oscilator(energetic efficency aprox. 80%) who deliver power to load when T is blocked. Here Tito say to control brake on peak....
similarity with tito's doc1_2.JPG = A&V for  similarity with tito's doc1_1.JPG
similarity with tito's doc2.JPG = diagram show how is modified F osc., I diode when P load is changed
similarity with tito's doc3.JPG = diagram show priciple to stabilize output voltage at autobloking oscilator
similarity with tito's doc4_1.JPG =  principle for  old tv power supply, made in Germany, named CESSY(Compact Energy Saving System). Theoretichal energetic efficency is arround 95% !!! . 220V/50hz can be any voltage for us.
similarity with tito's doc4_2.JPG = show variation Volt. on T2 and  Amp on Ls ( BDO is name for L of yoke...)
If you consider useful, i can give more information. For me is am ideea to start somehow...
I think Tito give us a mix of information from multiple projects....
for start we need a block diagram...how do you think? Theory is great but is nothing except checking in practice. Then step by step, we can go away... only STEP BY STEP and verify, and re-verify every step! For this we need a block diagram!
This are my proposals for START!
With your advice I can proceed to start  at work!
good luck and God bless you!
Light ... for you !!!
light2011
with regret I assist to dead a good ideea...
I will work alone and I post result on new...story!
Good luck to every one to road to OU!
Bob Smith
@ Light2011,
Before you go, take a look at image #6 (2nd row down, right hand side) at this link:
http://www.overunity.com/6763/energy-amplification/msg301294/#msg301294
Tito has mentioned over the course of this thread that his setup is fairly simple:
- wire
- caps
- discharging into coils
- diodes
- avramenko plug
He has also mentioned the need for balance in the system.
I personally believe this apparatus involves a wire (perhaps a TPU type of iron coil, shorted), a coil perpendicular to the wire (possibly shorted) with a secondary, discharging into cap through a diode, back into coil-diode-cap, coil-diode-cap and possibly an Avramenko plug to a resistive load.  In this way, you have cascading discharges, possibly drawing in cold electricity from the aether.  I may or may not be right, but I invite your consideration.
Bob
crazycut06
Quote from: light2011 on January 25, 2012, 05:55:05 AM
Hi Light2011,
Don't be discouraged if no one answers your post, just continue experimenting and posting here, everybody will be glad of it....
cause sometimes everybody is busy doing other experiments...
God bless us all!
Magluvin
Quote from: Bob Smith on January 25, 2012, 06:09:50 PM
@ Light2011,
- wire
- caps
- diodes
- avramenko plug
Bob
These are a lot of what Tito had talked about. In the ruff.  ;]
But I believe that there must be a way to have a self increasing oscillation. Either it can be started, kicked, then once it has self increased, then discharge to load or storage.
Or Kick, kick, kick till the level has been reached for discharge. Like Teslas little tapper box that made a whole building shake into resonance. Imagine the energy created from a bunch of miniscule taps.
Tito talked about being careful, big voltage can happen. So what if there is a configuration of coil, coils, bifi, trifi, caduceus, etc. that once started or kicked, that it could increase on its own, up to a level higher energy for discharge.
Possibly the tapper method would be safer, due to the possibility of the self riser of over doing itself. Safety measures would have to be worked out, which shouldnt be too difficult once we know what we are dealing with.
Mags
