ENERGY AMPLIFICATION
0 Members and 72 Guests are viewing this topic.
Tito L. Oracion
Good day everyone  ;D   ;)
Analyze the  kick ok.
What do you feel on the first kiss ?  :-*
What are the affected areas? LOL  ;D
is it bothering your tension? LOL  ;D
don't you wan't it to reserve it? lol  :D
what is your decision? LOL  ;D
I know what you think, you always want direct to the point  isn't it? :D   ;D  lol
Always kicking is what you want isn't it ? lol hahahahahahahhahhahahah  ;D   ;D   ;D   ;D   ;D
The many the kick the better isn't it, kicking! kicking! kicking! lol hahahahahahahhaha  :D   :D   :D   :D   :D
Then everything gets crazy!  ;D
LOL  :D :D :D :D :D   ;D
VERY FUNNY BUT TRUTH HAHAHAHAHAHAHH LOL
WHY ARE YOU THINKING MALICIOUSLY?  lol joke
8)  MATRIX OTITS  ;D
forest
Tito, what you described looks like many kicks into one big kick. What is the source ?  Capacitor or coil ? or Both ?
How resonance is catching aether energy ??/?!!!!!!    :o :o :o :o :o
Tito, please see this http://www.overunity.com/11961/ghazanfar-ali-generator-utlilizing-trapped-energy/ and comment .
Magluvin
Im thinking Tito is claiming 1 of 2 things
1  kicking the coil at resonance, meaning the kicks happen every cycle of resonance in the shorted bifi. The kicks are in sync with the coils freq.
2  Kicking the shorted bifi and draining power from it with a secondary till the oscillation minimizes then kick again.
Im gunna go with 2
But both should be tested.  Going with 2 at first is easier. We dont have to have a circuit that is in sync with the coil. We should be able to monitor the coil for resonance and output 1 kick at a time. Unless the kicks are so small that the coil needs to build in oscillation. If thats the case, then the in sync method would be the next step.
Im going off of Titos first drawing posted. If he was using a relay for kicking, it might be hard to get sync due to low freq switching speeds.   Not sure yet, just thinking.
Mags
Magluvin
Considering Titos caution statements, the input kicks should be small in power at first and increase with caution.
We will see.  :o Ooo Ooo
Mags
Bob Smith
Hi Mags,
I tried with a shorted soft steel coil to produce a PMH type of magnetic current, and put a secondary on it (perpendicular) and ran it into a "Free Energy from Thin Air" circuit (caps & diodes). A few milliamps was all it gave (I've only stepped it up once, and know it can be improved by adding layers of caps, and allowing them to discharge into coils - just need time to experiment.)
However, I gather from Tito's and your remarks that the primary/secondary is two coils in one, and your above post is suggesting that this is a shorted bifi coil.  Stephan has an interesting comment from an email he received (in Tariel Kapanadze thread) about an iron-copper coil. I'm wondering if this might shed some light. Here's the link:
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg312292/#msg312292
Here's the quote:
QuoteIf you don't want the power but to see just a glimpse of the kicks you can simply wind a double interleaved coil one lead copper one lead iron like so:
http://i43.tinypic.com/120mcjp.jpg
Drill small holes for the wires like so:
http://i40.tinypic.com/a2dkps.jpg
Make sure it's wound like so:
http://i44.tinypic.com/2drb0ow.jpg
Wind them interleaved but make sure they stay as two separate coils, they are in no way electrically connected to each other.
When this coil is connected to a transistor like is explained exactly in the Carl Doc, one lead serves as trigger the other lead for output, it will act like a blocking oscillator and you can tune it to produce audible tones, and you have a good coil when it reacts heavily to the earths magnetic field.
By this i mean when it produces a steady tone and you move it the frequency will change dramatically.
Of course it will also respond to a magnet and it can respond to both at the same time if the fields correctly blend into each other.
Take it to the next level by hooking it up to a signal source and a scope, and raise the frequency watching the scope carefully.
My problem is that Stephan says "Wind them interleaved but make sure they stay as two separate coils, they are in no way electrically connected to each other" - that is, they're not shorted together.  Add to this that BruceTPU says that the 2 coils in the TPU are actually copper and aluminum.  -- I'm not sure where to go from here. Would you suggest a shorted bifi iron or soft steel primary/secondary bifi?
Regards,
Bob
