ENERGY AMPLIFICATION
0 Members and 90 Guests are viewing this topic.
Magluvin
Yea, I saw Woopys vid. Looks good. I need to look at the 3d drawing and draw it out to better understand it.
Thanks for the input guys.
I had seen Cody's vids before.  From what I had figured, with a closed core toroid, that when the charging field is built, it sticks to the loop of the core due to the cores attraction and the fact that it is a loop. Like if the core were used in a push pull transformer, the primary fires 1 phase, then the primary is fired with opposite polarity, which would unlock the previously stuck field, getting stuck back and forth.
I believe that is why they use some E cores with a gap on the center peg. So for every primary input, the field doesnt get stuck.  I have to look it up, I have a book around here with that info. Which one?  lol  Ill look.  There was a reason for it.
But if we were to sustain the stuck field, all operations would need to be of a proper polarity as to not unstick the field. And do we want to build upon it, which is always a possibility up until saturation.
As for the zener diodes, I think Tito meant them for some part for his replacement of the spark gap. So it may only be a level trigger device to activate a transistor/mosfet for kickin.  Its the 3v part that trips me up, since I believe he is using HV.
Its hard. No schematic, just vague partial parts lists, of more than one way to do, well, do anything.  lol  Eh so what.   I really cant think of a better thing to do. ;]
Mags
Goat
Hi All
Please check out the circuit(s) in the kornelsons-free-energy-transformer http://www.overunity.com/12086/kornelsons-free-energy-transformer/new/#new
I think some of the principles discussed in this thread might apply, it seems like a very simple circuit that many here could test quickly to verify if it could work.
Edit:  Attaching circuits so everyone can see them here in this thread.
Regards,
Paul
crazycut06
Quote from: Goat on February 26, 2012, 07:09:15 AM
Hi All
Regards,
Paul
Hi Goat,
     Thank you for sharing... Informative and very well explained...
Goat
@ crazycut06
Thanks for your reply, the more I look at the second schematic the more I think there is no need for fancy electronic circuits or even the need for commutators!!!
If you look at the schematic it appears that the switches are the motor drive connections, I just can't see right now how the first motor would enable the second switch and so on to the last motor.
I'm going to sit back and think about this one awhile.
Edit:  As a thought experiment I got rid of all the switches in the second schematic by attaching either pulleys and belts or even better a proper matched set of gear pulleys that matched motor1 to motor2 and so on to motor4 so that the switch is replaced by the timing of the gears (or pulleys) to make motor contact at the right timing.
Hope that makes sense.
Regards,
Paul
