ENERGY AMPLIFICATION
0 Members and 85 Guests are viewing this topic.
Bob Smith
My bench time is limited right now due to travel. But I did have time to quickly wind up a 5 inch coil of 18 gauge multistrand shorted bifi lamp wire. I put 1 loop of 26 gauge single strand bifi wire perpendicular around the whole thing, with 2 small ceramic caps between the shorted ends (i.e., wire-cap-wire/wire-cap-wire). -Not exactly what Teets specifies, but it's what's at hand right now as I'm on the fly.
I pulsed the shorted perpendicular wire manually and noticed the degrading voltage in the coil with my cheapo digital meter. Couldn't get anything on the scope, but don't have time to fiddle. Was hoping to see a series of diminishing pulses/kicks. Oh well, will try again later in the week.
If the larger (single or bifi) coil is shorted (instead of series wound), I believe it retains its inductive properties. I think this is what we want in terms of kick, don't we? - Primary and secondary kicking back at each other?
FWIW
Bob
edit: correction on wire gauge
crazycut06
  Good thinking Bob, I'm reading the utkin Pdf reg. the shorted coil, and trying to experiment with it using a rotor, but no results so far, maybe it's easier if I try it in solid state with the help of a scope,  Am still waiting for my nano scope to arrive.
Regards Cc
Tito L. Oracion
Counsel[/size]
Speaking of your not having perfectly undamped waves at that time, you were referring to that character of circuit?[/size]
Tesla[/size]
Yes, but with another kind of circuit I could, of course.  The advantage of this apparatus was the delivering of energy at short intervals whereby one could increase activity, and with this scheme I was able to perform all of those wonderful experiments which have been reprinted from time to time in the technical papers.  I would take energy out of a circuit at rates of hundreds or thousands of horsepower.  In Colorado, I reached 18 million horsepower activities, but that was always by this device: Energy stored in the condenser and discharged in an inconceivably small interval of time.  You could not produce that activity with an undamped wave.  The damped wave is of advantage because it gives you, with a generator of 1 kilowatt, an activity of 2,000, 3,000, 4,000, or 5,000 kilowatts; whereas, if you have a continuous or undamped wave, 1 kilowatt gives you only wave energy at the rate of 1 kilowatt and nothing more.  That is the reason why the system with a quenched gap has become popular.[/size]
I have refined this so that I have been able to take energy out of engines by drawing on their momentum.  For instance, if the engine is of 200 horsepower, I take the energy out for a minute interval of time, at a rate of 5,000 or 6,000 horsepower, then I store [it] in a condenser and discharge the same at the rate of several millions of horsepower.  That is how these wonderful effects are produced.  The condenser is the most wonderful instrument, as I have stated in my writings, because it enables us to attain greater activities than are practical with explosives.  There is no limit to the energy which you can develop with a condenser.  There is a limit to the energy which you can develop with an explosive.[/size]
A common experiment, for instance, in my laboratory on Houston Street, was to pass through a coil energy at a rate of several thousand horsepower, put a piece of thick tinfoil on a stick, and approach it to that coil.  The tinfoil would melt, and would not only melt, but while it was still in that form, it would be evaporated and the whole process took place in so small an interval of time that it was like a cannon shot.  Instantly I put it there, there was an explosion.  That was a striking experiment.  It simply showed the power of the condenser, and at that time I was so reckless that in order to demonstrate to my visitors that my theories were correct, I would stick my head into that coil and I was not hurt; but, I would not do it now.[/size]
In a single isolated transformer, we have the primary and secondary, now the primary is connected to the source, because of the effect of primary the secondary power is generated without connection to the primary, its a clear gain in the secondary is it not?
its just 1 +1 equals = free energy
In battery and 1 cap: charge the cap then connect them in series you get more volts than the source is it not?
Tito L. Oracion
Here is your TPU
Counsel[/size]
Mr. Tesla, at that point, what did you mean by electro-magnetic momentum?[/size]
Tesla[/size]
I mean that you have to have in the circuit, inertia. You have to have a large self-inductance in order that you may accomplish two things: First, a comparatively low frequency, which will reduce the radiation of the electromagnetic waves to a comparatively small value, and second, a great resonant effect.  That is not possible in an antenna, for instance, of large capacity and small self-inductance.  A large capacity and small self-inductance is the poorest kind of circuit which can be constructed; it gives a very small resonant effect.  That was the reason why in my experiments in Colorado the energies were 1,000 times greater than in the present antennae.[/size]
Counsel[/size]
You say the energy was 1,000 times greater.  Do you mean that the voltage was increased, or the current, or both?[/size]
Tesla[/size]
Yes [both].  To be more explicit, I take a very large self-inductance and a comparatively small capacity, which I have constructed in a certain way so that the electricity cannot leak out.  I thus obtain a low frequency; but, as you know, the electromagnetic radiation is proportionate to the square root of the capacity divided by the self-induction.  I do not permit the energy to go out; I accumulate in that circuit a tremendous energy.  When the high potential is attained, if I want to give off electromagnetic waves, I do so, but I prefer to reduce those waves in quantity and pass a current into the earth, because electromagnetic wave energy is not recoverable while that [earth] current is entirely recoverable, being the energy stored in an elastic system.[/size]
tesla implying a great control of his circuit! even it is 1000 time greater than ordinary.  8)
