ENERGY AMPLIFICATION
Dave45
I dont know if you guys read my ramblings over on energetic, but I finally see whats happening and how to draw energy from the magnetic field, it takes six coils to make free energy, the number of man.
http://www.energeticforum.com/renewable-energy/9656-electric-field-magnet-35.html#post204829
start here and read till the end.
Like Tito says connect the end of the primary's to the beginning of the secondary's
Make the world free
Help the poor
dave
Mags I believe you can do this.
Dave45
You dont have to drive the system with high voltage, SM did it with a nine volt battery and flip flop circuit, I dont know if he ever looped the system but you really dont have to using two batteries one charging one running the system and change them when depleted.
But then again you guys will figure it out, I believe in you.
dave
Dave45
I believe it can be done Don Smith style, winding on two inch pvc, air coils, but that remains to be seen,
SM put his circuitry in the center of the toroid, this kept his circuitry out of the electric field that orbits the toroid, dont know if this will be a problem with the Don Smith setup or not.
Magluvin
Quote from: Dave45 on August 18, 2012, 07:21:56 AM
Make the world free
Help the poor
dave
hey Dave
I apparently have an acct at energetic, but I cant do anything. Im logged in, but no privilege to read your thread. I have not been there in a long time.
maybe you can post something here. ;]
I can see how attaching the open end of the sec to the primary will affect the output. But if I attach it to anything, the output is affected. Maybe attaching to 1 particular leg has a different effect than the other? Or attaching to the primary affects the transformer as a whole, capacitive effect?
MaGs
Dave45
If you'll bare with me I start here http://electronics.howstuffworks.com/inductor1.htm
The reason for this strange behavior is the inductor. When current first starts flowing in the coil, the coil wants to build up a magnetic field. While the field is building, the coil inhibits the flow of current. Once the field is built, current can flow normally through the wire. When the switch gets opened, the magnetic field around the coil keeps current flowing in the coil until the field collapses. This current keeps the bulb lit for a period of time even though the switch is open. In other words, an inductor can store energy in its magnetic field, and an inductor tends to resist any change in the amount of current flowing through it.
The inductor stores energy in its magnetic field it comes back to source in the form of bemf (high voltage) but also moves forward femf in the form of high current to keep the light bulb lit after the switch is open.
I developed a magnetic field model long ago so I figured if it held water I should be able to tell what was happening by looking at the model.
I realized the inductor not only stores energy in its magnetic field but also separates the voltage from the current in the form of cw and ccw fields.
So what happens when the inductor is shut off the bemf (high voltage) comes back to source the femf (high current) moves forward into source.
I thought this is why high voltage is easy to collect but current is hard to collect because it runs on to source, so I started looking at the tank circuit but realized every time the energy is collected in the cap and released back through the inductor the same problem occurs the magnetic field builds the voltage come back and current follows on through.
I studied on this for awhile and it was something Tito said over on the Ali thread that made a lot of sense, connect the end of the primary to the beginning of the secondary, this way the current runs on into the secondary.
I pondered this for awhile then remembered I was playing with a cw winging and ccw winding on a iron core and noticed if both coils were powered from the center the poles stayed the same they didnt switch, so I started looking at this in relation to the magnetic field and its cw and ccw storage system and realized if one coil was cw its bemf would be voltage and its femf would be current and the other coil ccw its bemf would be current and its femf would be voltage, the poles never change.
I have always been a big fan of Leedskalnin and long ago realized any free energy device would have to have the shorted coils that make his pmh work, they create a standing field that can be drained from.
This is getting long winded so I will cut to the chase
wind one coil trifilar cw
wind another coil trifilar ccw
first wire on each coil set is the primary
second wire on each coil set connected as per leedskalnin's pmh - shorted coils
the last wire on each coil set is the secondary one will put out voltage the other current
Ok we want our voltage and current to be out of phase so we need to drive the coil sets out of phase, we can do this with the flip flop circuit.
Connect the end of the primary's in each coil set to the beginning of the secondary's in each coil set, thanks Tito.
The system will pull energy from the magnetic field naturally without flipping the poles or breaking the dipole.
I did some experiments with ice long ago and realized that the electric field wants to be parallel to the earth, build the coils in a vertical orientation.
