ENERGY AMPLIFICATION
0 Members and 101 Guests are viewing this topic.
Dave45
If wound on a toroid we have the TPU.  ;)
SM powered his TPU with a nine volt battery and the flip flop circuit.
Dave45
The shorted coils catch the bemf from the opposite primary, one shorted coil will produce a voltage standing wave and the other shorted coil will produce a current standing wave both will be above the appropriate coil set and will add to the femf of each coil set.
The system will work naturally with the magnetic fields and will pump energy out.
Magluvin
Quote from: Dave45 on August 18, 2012, 10:32:46 PM
I studied on this for awhile and it was something Tito said over on the Ali thread that made a lot of sense, connect the end of the primary to the beginning of the secondary, this way the current runs on into the secondary.
Hey Dave.  I have to read it over again. But is this like saying if we have 2 secondaries, one of high V and low A, and one of low V and high A, that if we connect them in series we end up with an output of high V and high A?
MaGs
Dave45
Iv studied this but have only got this far, Im not sure about the connections after the secondary's,
Im going to build this soon, experience is the best teacher.
Im not as good at electronics as you guy's but I will give it a go.
I see whats happening in the coil reactions, it will work.
dave
Tito L. Oracion
I have discovered much more better than the fluctuating energy.
The freely flows of electricity from the vacuum is really true and the advantage of it is that we are not anymore loosing switches and no spark or arching.
And the most better from it is that, we can doit in a very small quantity and unlimited strength.
here is the clue number 1:
if we got an increase then we should have to scruitinize that and lift that up ok?
that's all for now;  ;)
otits L. Noicaro
