ENERGY AMPLIFICATION
0 Members and 117 Guests are viewing this topic.
Dave45
Here is a visual representation of how to pull energy out of an electromagnetic system
Notice the direction of the applied current into the system
Dave45
Also notice the femf on each side one voltage one amperage  ;D
Tito L. Oracion
Quote from: forest on August 20, 2012, 07:42:10 AM
That one ? : http://www.teslauniverse.com/nikola-tesla-patents-609,250-electrical-igniter
Use magnifying glass.Frankly I don't see anything exacept when secondary is closed by spark energy can go via piston to the primary.  ::)
Teetsla quote 1:"Everything is running in a momentum state, in order to run it smoothly and well balance,
                            then the design should be naturally,
                            physically and materially fit." 8)
                       2: Free energy is just a matter of  I + E
                           where: I=input
                                       E=effect
                       3: To solve a mystery then be a Mysterious, and being mysterious your mind should be running in different dimension.
                       4: No matter how far human being can achieve, the end of it is spirit tech.  8)
And for the  quote 5: Still thinking, quiettttttttttt!  >:( ::)
;D
No! The one with the high frequency high currents high voltage.
and also read this to astray you more:  [size=78%]http://www.slideshare.net/BioFaAreS/ebook-free-energy-secrets-with-tesla-patents-9501580[/size]  joke
;D
Tito L. Oracion
Quote from: lancaIV on August 20, 2012, 05:39:04 PM
Fine Mr.Oracion, stay as you are. :)
Many waves leaving Romes(I,II,III,...).
Greetings
                  CdL
High everyone: What does Lanca means about this?
is he threatening me?
are those waves tsunami from rome?
can we collect those waves?
please answer me, i'm super scared ooooohhhhhh  :( :'(
you bad ha :D
buddy qwert,  i trust you, please explain it to me is he a phsycologist student?. :D
                       could you send me a gun to neutralize this wave  coming from rome?
                       well, i will now make my hydrogen gun for those waves  :D
;D
Dave45
Quote from: TinselKoala on August 20, 2012, 06:16:35 PM
When a coil is wound in the normal "back and forth" layers.... you never reverse direction, you are always winding either CW or CCW. Point the thumb of your hand along the wire and watch which way your fingers curl. Slide your hand along the wire, you will find that the "curl" of your fingers is always in the same direction. Or simply watch what direction you turn the crank of your coil winder... you never reverse it, each layer, back and forth, is wound in the same direction.
If you take a long wire and double it by folding it at the center, so both ends are in your hand and the fold is at the distance... then wind this onto a form, you will have a coil that "reverses sense" because if you do the thumb and fingers trick again you will see that the sense of curvature of your fingers reverses at the fold. This form of winding is called "hairpin bifilar" and is a good way to make a non-inductive or reduced inductance coil, as the "fingers" of one half counteract the "fingers" of the other half. You can cut the wire at the fold, and now you can make a true Tesla bifilar winding out of it by taking the "fold" end of one wire and connecting it to the free end of the other wire. Now, once again your "sense" is the same all the way around, either CW or CCW, but you will have increased energy storage in inter-winding capacitance.
When you wind your next conventional coil think of a particle moving in one direction away from you traveling in the wire when you reach the end and start winding back turn the coil around and notice the direction of the winding, remember the particle is moving through the wire away from you. You have to look at it from the particle's perspective.
