ENERGY AMPLIFICATION
0 Members and 79 Guests are viewing this topic.
Dave45
Seems I had a mistake in the pic, fixed it.
Dave45
Is it frequency dependent, if we use the same size wire for all our windings.
We are not trying to convert voltage to amperage in the normal transformer type windings, we are unraveling the magnetic field, pulling it apart and channeling the fields.
Dave45
I would think that the voltage or the amperage could be increased or decreased by using less or more windings on either side.
In others words one coil set could be ten winds while the other could be twenty.
dave
Magluvin
Hey Dave
Thanks for the good words. ;]
If you wind 2 input or primary coils together and put them in series, and on that center tap connect B+ and use mosfets to alternately pulse the ends of the primary with -V then one coil will induce one way and the other coil will induce the other way. They use this method in car amplifier power supplies.
Driving the mosfets can be done with a PWM IC, many available and freq adjustable.
You can use a flip flop IC to switch the fets, with a 555 timer set to 50% duty to trigger the flips and flops, while the freq of the 555 is also adjustable.
MaGs
