ENERGY AMPLIFICATION
0 Members and 131 Guests are viewing this topic.
forest
tip #2 was about ? :
- capacitor discharge
- stout bar with a tail coil
- using magnets on rotary generator
- using carbon on discharge path
- amplification by positive feedback
my memory is falling...
Qwert
Tip #1:
http://www.overunity.com/index.php?topic=6763.msg198942#msg198942
Quote from: Tito L. Oracion on August 27, 2009, 11:02:55 PM
...A tip to all of you: study the real process or the real thing that is happening when charging many caps of at least 10K uf in high voltage dc and discharging it sequencially in a coil with secondary! the only secret here is how you connect the caps from battery and coil efficiently! thats it you have it.
offcourse you pulse it!
otits
This is an additional information to the above tip#1; it can also serve as the tip #2:
http://www.overunity.com/index.php?topic=6763.msg199059#msg199059
Quote from: Tito L. Oracion on August 28, 2009, 06:31:54 PM
Quote from: stprue on August 28, 2009, 08:57:00 AM
Are you charging them all at the same time and then using something along the lines of a led chaser circuit for discharging?  ...and probably some back into the coil and some caps for useable energy?
well, partly you are correct but there is still missing, the technique of using other coil making a kick without using any current from the input and that makes excess or unlimited energy. and i got this technique in henderson file.
my device is a combination of tom bearden, henderson and bedini.
sorry i'll be busy now, i cannot respond always.
God bless
otits
Another tip:
http://www.overunity.com/index.php?topic=6763.msg199184#msg199184
Quote from: Tito L. Oracion on August 29, 2009, 06:26:30 PM
CAPACITOR IS THE SOLUTION!!!
And another tip:
http://www.overunity.com/index.php?topic=6763.msg199188#msg199188
Quote from: Tito L. Oracion on August 29, 2009, 06:52:16 PM
i think no need for measurement if you are using your device for one straight week without charging the battery and using 300 watts of power from your inverter. all i need is that it can stand everyday ok.
And finely:
http://www.overunity.com/index.php?topic=6763.msg199210#msg199210
Quote from: Tito L. Oracion on August 29, 2009, 10:03:42 PM
i will prove nothing but i encourage everyone to study this field if you really want to see real power!.
study the tesla's wiring style, efficiency is in there.
still tesla's technique is the superior method!. believe it or not.
And an expert's word:
http://www.overunity.com/index.php?topic=6763.msg200761#msg200761
Quote from: otto on September 11, 2009, 03:12:02 AM
Hello all,
it seems that I was a little bit blind so I didnt see this thread. and especially the posted "Sweet drawing".
For years now Im insisting to use this drawing to build a TPU. It has to be a little bit modified because of the number of turns, connections.... Nobody was listening as always.
Tito,  your doing a great job.
Otto
Here is the "Sweet drawing" that Otto mentions:
http://www.overunity.com/index.php?topic=6763.msg155915#msg155915
forest
Ok, I remember now  ;D
Tip #1 is about charging many capacitors in series and discharge in parallel.A LOT of capacitors for small gain probably.
I think Tito later said that Tesla wiring coil method is superior just because that - we don't need so much capacitors.
Ahh...here are two methods Tito mentioned! Capacitor method and coil method. I bet first try was to use many capacitors as per tip #1. Still the superior device is using positive feedback to convert little kicks into big current kicks, that would be also the smallest and simplest in construction (not in operation of course)
I'm more interested in external power source used - is that directly tapping vacuum energy or indirectly through our Earth "wheelwork of nature" ?
IndianaBoys
Can anyone tell us the medium and high frequencies that were being used in the TPU Flash Over video on youtube?
TPU FLASH OVER
http://www.youtube.com/watch?v=vsZ0EC2VeJw
Thanks,
IndianaBoys
dasimpson
a self running machine is easy the hard part is getting a machine to self run and also power other things thats the hard part
Quote from: forest on October 01, 2009, 08:53:42 AM
wattsup,
While you are perfectly right about returning most of energy back to source in such way as to not deplete it but recharge, that will not explain all those devices which are self-runners with power source disconnected after first kick-start - vide Kapanadze device
