ENERGY AMPLIFICATION
0 Members and 171 Guests are viewing this topic.
forest
Quote from: Dave45 on October 08, 2012, 09:22:05 AM
The only problem would be the resonance would be that of the transformer and not the coils I want to drive.
Back to the other circuit
I like schematic but can you or somebody draw real current flow here ? I feel that this capacitor is not placed good....maybe
crazycut06
Quote from: forest on November 06, 2012, 04:26:37 PM
yes! I think this is it ! with higher voltage you need less amps to get the same power, the only problem for me is how to stop this cascade without burning or exploding or wasting energy in heat
I wonder.... can you test something for me ? if we have a battery 12V with a diode connected to the capacitor, then charge this capacitor with voltage higher then battery and connect to that circuit and what is going on ? diode from plus of battery to plus of capacitor so current can only flow from battery to cap without return
anybody ??
That's one problem thats needs to be overcome, coil heats up, but if the coil is in resonance wouldn't that stop the heating issue? I remembered my past experiment where my coils don't heat up much and i get more power out, maybe im hittin the resonance state of the coil i used? Dunno, co'z i don't have a scope  ;D
forest
Quote from: crazycut06 on November 06, 2012, 06:07:48 PM
Heat is no a big problem, just make it not too high frequency, maybe add capacitance to coil to lower this. The problem is that recovery is high spike high voltage. Now I know why Tito and Aviso insisted to switch capacitors between series and parallel connections.
In short words : we have to find a very fast way to push energy from high voltage stage into lower voltage in no time, like DC-DC convertion with always the same voltage a the end while the voltage from start is variable. Hard task, hmmm ???   :o
Tito L. Oracion
Quote from: crazycut06 on November 06, 2012, 12:44:08 AM
Hi Sir Teets,
With this circuit 12v to 48vdc, if we use another circuit to pulse the 48v we will get much higher voltage? Cascading? Will the current amplify also? Or we loose amps on higher voltage? Wahtcha think?  ;D
Pag X'former ang ginamit mo at pataasin ang voltahe syempre liliit ang current dahil mas payat ang gagamitin mong secondaries coil di ba.
Pero pag ang design ay hiwalay ang constant current source sa voltage source at pagsamahin mo sa output then.  ;)
Pero hindi ito ang techinique ni tesla, ang kay tesla ay mas simple at konti lang gagamitin mong electronic components. tatlo lang yon.  ;)
Pero ang advantage nung sa video ay maganda rin dahil pwedi mong gawing maliitan yung design. enough for single appliances. so ang labas ay Pweding magkaroon ng sarisariling power source ang bawat appliances.  :)
Note! umiinit lang ang device pag dimo control at mataas ang labas ng current, in short overload.  ;)
Hanggang sa muli kaibigan  ;)
Tito L. Oracion  ;D
Bob Smith
Tito's comments thru google translate:
X'former're used to and of course voltahe smaller increase for the current thinner coil secondaries used to know.
But when the design is separate constant current source with voltage source and then combine the output.
But this is not the techinique of Tesla, Tesla's comments are simpler and little used only to electronic components.tatlo just that.
But the advantage Nung video is beautiful as well as those pwedi to make maliitan design. enough for single appliances. so the outside is Pweding have sarisariling each power source appliances.
Note! Just warms the device Dimo control and high out of current, in short overload.
Up to re-friend
     Undo edits
