ENERGY AMPLIFICATION
0 Members and 122 Guests are viewing this topic.
Tito L. Oracion
Quote from: forest on November 20, 2012, 01:27:39 AM
however switchmode inverter using high frequency can be small except capacitors and maybe mosfets with heatsink
Ya, :)  i also agree with you, but what i'm saying is that the tesla almost pure coil free energy makes bulky device defending on the watts, like for example the 100kv of TK.
in using almost all electronic component, i think they cannot handle the power very much, well, there are solutions but their life is just from 5-15 years in comparison to tesla tech that can reach up to 30 years.  8)
Tito L. Oracion
Quote from: Magluvin on November 21, 2012, 09:25:20 PM
What you say about the heat, Tesla talked about using instead of round wire, using ribbon or strips. I have to read it again, I think he didnt know if it was the larger surface area of the ribbon or another reason heat was less of a factor. Tesla. Would loved to have known him. ;) Some laptop supplies, some of the transformers have at least 1  flat ribbon winding. Ive had one that had 2.  Also, an arc welder I was checking out, large, 10 in. by 10 in. laminated core, 3 in thick. The primary was like 1/4 in. round copper and the sec was 2 different windings of  flat windings, one was for high power and the other for low.  Picture a square core wound like we see a toroid in a diagram, primary on one side and sec on the other. but this being square, there is one more ingredient to the welder....
A large knob on the front casing was connected to a shaft, with a rectangular laminated block, suspended on the core between the windings. When you turn the big knob, the rectangular core can be turned to where the rectangle block acts as a magnetic shunt to make output adjustments.
The core was all rusted out and Im sure the laminations were no longer separated from each other.  ;)
Anyways...
So with proportions/power, are you saying we can relate common electronics, or particularly , power supplies, like cell phone, or laptop size, to what power we could expect from an ou device?  Or would the ou device be larger in comparison?
Happy Thanks Giving, no matter where you are.  ;)
Mags  ;D
well, i believe Tesla has a reason.  ;)
As i am looking the design of a radiator of an auto, it seems that tesla is right. :)
The thing that faster to cool is something that tesla is referring.
Tito L. Oracion
ok!
Believe it or not the battery was just used as an alternative negative common ground. because if you notice his designs in wireless tech, all of his sketch are connected to earth ground, obviously he cannot carry the earth ground in a four wheels  ;)
and obviously nobody answer that. heheheheheheh lol
bboj
That is obvious. The question is where the extra energy comes from. Where is it pumped from.
forest
Quote from: bboj on November 25, 2012, 08:55:21 AM
From the same source which gives us gravitation....
