ENERGY AMPLIFICATION
0 Members and 145 Guests are viewing this topic.
bboj
bboj
And what mechanism you propose for pumping
Magluvin
Quote from: Tito L. Oracion on November 25, 2012, 02:48:53 AM
ok!
Believe it or not the battery was just used as an alternative negative common ground. because if you notice his designs in wireless tech, all of his sketch are connected to earth ground, obviously he cannot carry the earth ground in a four wheels  ;)
and obviously nobody answer that. heheheheheheh lol
Hmm. So why not use the car chassis as an alternative ground? What properties of the battery enable it to be a ground alternative, but the car chassis not?
Mags
forest
I don't have a complete theory, nor I do care. All I want is to make a home heater without consuming energy  ;D
Anyway, I proposed experiment which every bigger scientific lab could make in minutes, if having proper materials.
http://www.supertightstuff.com/04/10/featured/superconductors-and-magnetic-levitation/
However my proposition is about a modification to this experiment. Lastly scientists can produce thin superconductor sheets and also thin very strong neodymium magnets.
They should create a thin round superconductor and then completely opaque it with thin superconductor.
Then such composite should be cooled down and watched....if it would levitate or even flow up outside the Earth then connection between magnetic field and gravity will be proven.
Qwert
"Opaque" is an adjective, meaning: not transparent; and it makes no sense in this sentence. You probably meant: "to envelope" or "to encapsulate" (in this case).
