ENERGY AMPLIFICATION
0 Members and 40 Guests are viewing this topic.
Magluvin
Quote from: synchro1 on November 25, 2012, 10:38:02 PM
@Magluvin,
              You need to connect the other two poles to complete the series circuit, then your input voltage would be the sum of the two naturally. Just connecting two of the four poles would do nothing.
I know.  ;)   Was just a thought example. ;D
Mags
forest
I emabrrased. By mistake I took live wire connected to my circuit via transformer and the second end of primary O connected to my garden water pipe. It was working fine ! No need to use neutral wire at all.... I know that here in Europe somewhere the neutral wire is connected to ground wire but the point is that my garden water pipe is connected to my well via iron pipes and is located 20m from my house. What is going on ?
I tried it with inverter but it doesn't work at all.
I don't understand ground  :-[ , is that filled with current from all houses around ?
Magluvin
Quote from: forest on November 26, 2012, 01:44:00 AM
What circuit?
Mags
Tito L. Oracion
hey buddy don't forget that the chasis of a car is also connected in the negative pole of the battery right?  ;)
Now, i don't know exactly the correct word for it but the closest is the "buffer effect or a scratch" that is the use of the battery.
and that is the way i see it.  8)
AND IN THIS MANNER ALSO, I DON'T SEE A REASON WHY A BATTERY WILL NOT LAST LONGER? AM I RIGHT QWERT?  ::)
The reason why battery is used, it is because there is a pulling action with the two pole. did you get that ladies and gentlemen?  ;)
so that when a signal is detected in the antenna, then the electron in the negative pole will react to the proton made by the signal.
so then after that, the electron will go back to the negative pole of the battery because of the pulling effect of the protons in the other side of the battery. Did you get it again class?  ;)   ;D   8)
And That is the truth happening  to that thing.  ;)
Bye  HOPE IT CAN HELP TO EVERYONE  :D
GOD BLESS YOU ALL!!! :)
MERRY CHRISTMASS AND HAPPY NEW YEAR!!!!!!!! :-*
ALWAYS REMEMBER: A THOUSAND STEPS START WITH THE FIRST  ;)
UP TO NEXT EPISODE EVERYONE, I'M SO EXCITEMENT ;D HAHAHAHHAHAHAHAHAHAHA LOL
TITO L. ORACION  ;D
Magluvin
Soooo, we put a 1.8 meter antenna on the batt positive, and the neg works as a ground?
Mags
