ENERGY AMPLIFICATION
0 Members and 35 Guests are viewing this topic.
bboj
Quote from: Magluvin on November 26, 2012, 10:21:14 PM
Soooo, we put a 1.8 meter antenna on the batt positive, and the neg works as a ground?
Mags
I think antena on tthe negative through capacitor
synchro1
         Typically, the DC Ground to Earth Ground is made on the battery negative.
         Here's a video by Imhoteb of him lighting a 120 volt LED with 'ZERO AMP' draw. He has the bulb wired to the positive pole of the battery only, and the negative to the neutral Earth Ground. The natural oscillating frequency of magnatisem is 1.59 Khz. This must be the frequency of the positive battery to ground oscillation that's exciting the LED crystal into illumination with zero current draw. It may be possible to wire an endless number of 120 volt LED bulbs in series this way, and still maintain the zero amp draw! Excellent job!
http://www.youtube.com/watch?v=QR7dEJtP79A&feature=em-subs_digest
This older kind of Lights of America in the picture has been proof tested for series gain. Other newer bulbs are built with inhibiting circutry that can spoil this effect.
synchro1
"I took a 12 Volt battery and connected its positive terminal to one end of an LED bulb with enough series protection resistor. Then I connected the other end of the LED bulb to earth (soil with moisture outside my house). I did not connect the negative terminal of the battery to anything. I expected the bulb to glow, but it did not glow until I connected the negative terminal of the battery to the ground as well." This is apparently how Imtotob completes his circuit as stated by him in :18 seconds of his video. He registors zero amp draw! It's important to note that you can't use the same point for the battery Earth Ground! You need two different Earth Grounds! This completes the circuit. The voltage differential between the grounds generates the transverse oscillation in the standing wave!
Here's a good video on the electrical circuit by Bill Nye:
http://www.youtube.com/watch?v=rg-XFXdtZnQ
synchro1
At 1:40 of Bill Nye's video, he closes a blade switch on a battery and bulb in series, and shows the current runnng from the negative side of the battery through the bulb then into the positive pole of the battery. Just the opposite of what anyone else will tell you. Further they disscect a battery and show a carbon rod dieletric semi conductor core, connected to the positive node of the battery. The carbon core is inside an aluminum conductor cup connected to the negative side, with a chemical electrolite in between.
The Earth's molton iron core is rotating faster then the crust, like the roter in an electrical generator. Giga-watts are bled off to form the Earth's protective Electro Magnetic Field every second.
A carbon core is the positive dielectric or insulator core.  This material is electron vacuuous, and Power generated from the Earth's spinning Iron core flows into this electron deserted positive ground, through the LED and back into the second seperated groind exciting the crystal while completing the circuit. The light DIODE allows the fluctuating ground field to pass in one direction only to comple the circuit.  The current passes at a kilohertz frequency.
With the current not flowing, but standing still, a traverse oscillation vibrates the standing sine wave on the lateral plane. At 1.59 Khz, the constant oscillating frequency of magnatisem. This vibration is the same along the Bloch Wall in every permanent magnet. This is a natural phenomenon. and excites the crystal in the LED and lightes it up with zero amp draw. The standing oscillation and current flow dovetail to cause flickering in the bilb. The message from the Bill Nye video is that negative and positive are labeled backwards!
