ENERGY AMPLIFICATION
forest
My theory is that from positive terminal flows a signal, energy which causes the electron to move from negative terminal, or rather current flow, because electrons just bounce one to another. From negative terminal maybe there is a flow of energy too.
synchro1
@Forest,
Exactly. The dielectric grows saturated, and the surfeit of electrons travels to the conductor through the chemical electrolyte.
bboj
Quote from: Tito L. Oracion on November 26, 2012, 06:03:45 AM
hey buddy don't forget that the chasis of a car is also connected in the negative pole of the battery right?  ;)
Now, i don't know exactly the correct word for it but the closest is the "buffer effect or a scratch" that is the use of the battery.
and that is the way i see it.  8)
AND IN THIS MANNER ALSO, I DON'T SEE A REASON WHY A BATTERY WILL NOT LAST LONGER? AM I RIGHT QWERT?  ::)
What signal you detect in antenna?
The reason why battery is used, it is because there is a pulling action with the two pole. did you get that ladies and gentlemen?  ;)
so that when a signal is detected in the antenna, then the electron in the negative pole will react to the proton made by the signal.
so then after that, the electron will go back to the negative pole of the battery because of the pulling effect of the protons in the other side of the battery. Did you get it again class?  ;)   ;D   8)
And That is the truth happening  to that thing.  ;)
Bye  HOPE IT CAN HELP TO EVERYONE  :D
GOD BLESS YOU ALL!!! :)
MERRY CHRISTMASS AND HAPPY NEW YEAR!!!!!!!! :-*
ALWAYS REMEMBER: A THOUSAND STEPS START WITH THE FIRST  ;)
UP TO NEXT EPISODE EVERYONE, I'M SO EXCITEMENT ;D HAHAHAHHAHAHAHAHAHAHA LOL
TITO L. ORACION  ;D
synchro1
@bboj,
Once again, this says everything:
"The electron will go back to the negative pole of the battery because of the pulling effect of the protons in the other side of the battery".
NickZ
  All very interesting...
  Today I worked on a replication of the cross over circuit. Among other things I was able to light a single led by connecting it on to the transformer coil (secondary) and could light the bulb while holding the other end of the led in my hand. It lit both ways, that is with either polarity, or either way.
  The 10 led light bulb did also flicker at bit, which may prove something, along with a small voltage variation of maybe 1/2 to 1 volt.  I'm just getting into this circuit, but I thought that I'd add what I've found so far. The circuit is still discharging it's batteries, so I not seeing any free energy from it yet. I'm NOT using the AC ground, as I know that has leaching capacitive voltage, but no real current to it.  I do use an outside earth ground.
  I also feel this circuit has something in common with Dr. Stiffler's PSEC circuits.
  My two cents...
                               NickZ
  Ps. Tito:
        Thanks for the tip... Happy New Year, also.
