ENERGY AMPLIFICATION
0 Members and 110 Guests are viewing this topic.
Bob Smith
QuoteYou consider this question again:"When is the start of a kick? and how to make the best kick" ;)
You have to analyze the origin and effect of a kick. as SM stated it as the secret. ;)
I've always assumed the "kick" was the discharge from a capacitor. Granted, it's not going to be a "disruptive discharge" as specified by Tesla.  But still a kick. My theory is:
- the larger iron shorted wire coil on the TPU is picking up the earth's mag field.
- SM places a magnet on the coil to get the magnetic current circulating in the iron wire coil.
- Perpendicular copper wire coil on the iron wire coil picks up induced voltage (from the
   circulating mag current), which is fed into a cap.
- Cap discharges and you have a "kick."
Problem for me is:
- Does it discharge into another perpendicularly wound copper coil, and that one into
   another? (To provide multiple successive kicks)
- Do the caps charge in parallel and discharge in series? If this is the case, I believe you need
   a diode after the cap.
Another thing that concerns me is runaway -
- Tito mentioned using a fuse to prevent runaway and melt down.
If the above description has some merit, then
-  Multiple perpendicular coils with cap will produce multiple kicks and a ringing
   effect   in shorted  iron wire coil, which can be picked up and used for power by a
   perpendicularly wound coil.
My two cents. You guys are the giants and I'm a mouse, but trying to make sense of it all...
Bob
forest
Bob
There are no giants currently on Earth  ;) If you are mouse then I'm a piece of cheese  ;D
Anyway, very good theory. I'm working on kind of related devices but yet not found OU.
I believe we can use just ferrite core toroid instead of iron wire, only iron atoms are required to tap external magnetic field. If we ae talking about TPU then I have kind of confirmation that original event of TV explosion was related to yoke coil. Very interesting is also that Kapanadze used part of TV set electronics in his device.
Tito L. Oracion
oh boy its really getting excitement here. ;D
it seems that no one got a bulse eye  ;)  but Bob seems got the nearest points.  ;)
all of the needed components are there, its the arrangement only that make the real problem.  ;)   ::)
;D
forest
ha ha switching between parallel and series capacitor  connection  :P :P :P
Tesla ozone patent
OU comes from difference in TIMINGS
forest
