ENERGY AMPLIFICATION
0 Members and 112 Guests are viewing this topic.
totoalas
gayahin mo si steve rejuso dala family nya sa singapore nagconsultant sya sagot ng govt nila    iba utak sa pinas  2000 pesos n lang ngaun
Bob Smith
Check out this 1960 patent. It talks about negative resistance at low voltages using a degenerate semiconductor as voltage regulator - Teets mentioned using a diode as a voltage regulator recently - (see pat. page 3, lines 37-43, left column). Diagram is on page 1, see explanation on page 3, with special attention to line 59 and following (right column) for arrangement of cap, diode and inductor.
http://www.freepatentsonline.com/3104352.pdf
Here's an interesting quote (for what it's worth):
QuoteDegenerate semiconductor is used in laser diodes, Zener diodes and ohm contacts in ICs and as metal gates in many microelectronic MOS devices. http://www.expertsmind.com/questions/degenerate-and-non-degenerate-semiconductor-3016182.aspx
It seems to me a deg. semiconductor most a propos to Tito's device is either a zener or tunneling diode. I have to read more, but time is short right now.  I do know it's important to get straight the differences between avalanche breakdown and behaviour of a tunneling diode. I believe the zener in reverse bias exhibits some TD qualities, but I have to read more and sort it out. It may or may not be important.
Maybe somebody can pick up the fork and stab a little further at this :)
Bob
totoalas
After a 24 hour marathon review of otits comments
Hed been saying all along
CoilS caps and batteries  tito has aviso has it dingel has it no more secret to discover
Ftequency  rresonance airwaves
Kaya nga sabi ng mga nasnip ko ddmanda daw nila ang globe transmitter lalo daw silang naging tamad at 100% full time tambay
Happy nu yr
Totoalas
totoalas
Dr naksmatsu of japan the thing he want yo invent id majick
His device using cosmic rays used pizza sized capa plates to power his 30 rooms and sell exvess power to the grid
Check his yt and enjoy
Imtotob aka totoalas ;) ;)
Bob Smith
Quote from: Tito L. Oracion on December 04, 2012, 08:40:28 PM
THE FREE ENERGY COMES FROM THE REACTION OF THE COIL FROM THE EXTRA COIL  ;)   8)
AND in terms of the sun,
Its the reaction of the EXTRA electron from the silicon by means of heat.  ;)
and in term of Magnet,
Its the changing magnetic field that gives energy to the electron to move or flow.  ;)
ALL IN ALL: IT IS THE UNBALANCE DESIGN OF EVERYTHING THAT MAKES EVERYTHING FLOW AND SEEK FOR BALANCE.  ;)   8)
AND THAT IS THE TRUTH. :o
QuoteTHE FREE ENERGY COMES FROM THE REACTION OF THE COIL FROM THE EXTRA COIL  ;)   8) AND in terms of the sun,
-radiant energy (from the sun) in the main coil, picked up by bifilar secondary?
- bifi coil cancels transverse wave and secondary reflection from secondary to primary, thereby leaving primary isolated. Only longitudinal (scalar waves) present in bifi coil. Other coils can pick up same scalar energy without losses/change to primary.
QuoteIts the reaction of the EXTRA electron from the silicon by means of heat.  ;)
- if you discharge secondary bifi coil into cap using AV plug, then into coil, then fwd biased diode, you have mag flux in coil (after AV plug) and pulse from collapsing field fed into "silicon" diode?
QuoteIT IS THE UNBALANCE DESIGN OF EVERYTHING THAT MAKES EVERYTHING FLOW AND SEEK FOR BALANCE.  ;)   8)
-If your main coil is the receiver/antenna, and your pickup coil is bifi, you have no reflective losses between the bifi and receiver/antenna coil, and system stays open.
Only problem is, you've got a very small signal. I think that somewhere between the main coil (receiver/antenna) and bifi, you've got to use a voltage multiplier to boost the voltage, then discharge into AV plug -- cap--coil--diode.
Just thinking out loud. Will work at building now.
Bob
