ENERGY AMPLIFICATION
0 Members and 138 Guests are viewing this topic.
Neo-X
No problemo amigo
Its just like a test of faith
Tito is almost giving up the secret
- End of Quote -
I dont believe in tito. I think he was toying with us. He already said that he was pinochio. :D
totoalas
Latest smartscarecrow interview with aviso
Ladt sep 400 k usd from shareof stock still i r and d
Max 15 mins run before overheating
Mags is right  :)
pauldude000
Quote from: Tito L. Oracion on February 06, 2009, 01:45:08 AM
Hi everyone 8)
Currently i am trying to amplify a small voltage into high voltage and its current from milliamps to amps now
Can somebody demonstrate amplify a 1.5 volts with its milliamps into high voltage and from milliamps to amps? ::)
Thank you. ;)
God bless
otits
That is actually both simple and common.
Take 12V at 20A and pulse it through a transformer to get 2400V at .1A. Feed this voltage into a resonant tank consisting of a HV capacitor in parallel with a coil which has a spark gap in series. The capacitor stores up the current supplied until the voltage can break down the resistance of the spark gap, at which point the gap becomes conductive discharging the capacitor in a series of oscillations.
This arc across the gap however consists of high voltage at high amperage. Therefore you have ultimately converted low voltage at low amps ultimately to high voltage at high amps.
What has happened is that a little energy has been stored continuously over a long period of time and then been discharged over a very short period of time. This circuit is the basis for the primary circuit of either an Oudin or Tesla type coil.
However, to get constant high energy out of a circuit in which you put in low energy requires an extraneous energy source, either known or unknown.
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
Tito L. Oracion
Quote from: pauldude000 on January 31, 2013, 07:23:23 AM
hi buddy  ;)
at that time i'm questioning how to increase it and not starting from high currents.  :(
well, your way is correct but it kills the momentum. :)
that's is why you need an extraneous energy source, and yes that is not the way  ;)
pauldude000
Tito, say you need to crack an egg. There are many ways to crack an egg. You can use a light tap with the edge of a knife or fork. You can use a sledgehammer. You can build a Rube Goldberg machine. All three will crack an egg.
Which is more efficient, and why do people trying to figure out how to crack an egg use sledgehammers and Goldberg machines?
