ENERGY AMPLIFICATION
0 Members and 178 Guests are viewing this topic.
crazycut06
Quote from: gyulasun on February 04, 2013, 07:51:42 AM
Be suspicious for the solid iron core due to eddy current losses, maybe just use (painted) welding rods or isolated iron wire pieces bundled lengthwise in parallel and insert it into the core.
Yes, thanks for reminding, as this was just a quick test, i have cut several welding rods for my core, i only use the solid one for easy access in case i need to rewound the coil.
crazycut06
Quote from: gyulasun on February 04, 2013, 07:56:09 AM
Maybe you wish to unwind 100 turns from secondary L1 to have the same 200 turns like secondary L2 has.
Manual switching is good for a start to see how much the flyback pulse can recharge the input caps.  This flyback pulse level also depends on the coil inductances so use ferromagnetic core (without significant eddy losses).
Ill test this tomorrow and see the voltages it produces, maybe i need to wind more for higher voltage, will post results soon..
Cc
totoalas
Thanks for the winding tips
I have the whole night to digest and draw the circuit prior to construction
I have a lot of 23 awg  no problemo  18 ga from a salvaged flat screen tv
Manual switching
Do i need to put an insulation or tape around the cores
Winding is
1 From left to right then back  or
2 Unison winding from left to right and cut winding then another left to right
And so on for clockwise and vise versa for ccw
3Do i need insulation for each layer
Thanks
totoalas
Quote from: crazycut06 on February 04, 2013, 08:29:58 AM
Cc
Cc
Capsrelay using square caps from a fluorescent fixture and a relay 12 or 24 v 2no 2nc is the one i will use
Also can you post a sketch of ur set up for comparison
Tnks
forest
in 93 times podmod  :P
tito ping pong  ::)
me thinks arduino would help  ???
podmod forever  :P :P :P
