ENERGY AMPLIFICATION
0 Members and 95 Guests are viewing this topic.
totoalas
Hi gyula
I should be the one asking since tito had repeatedly told this  lol
Yes this is my idea
But the connection maybe external supply for the meantime
Any suhhestion please let me know
Either to connect  to the 2 pulsinh precharged cap or on the load side
I just eoke up and will go to wok in my grave night shift
gyulasun
Hi totoalas,
Nice idea for switching, I remember Tito mentioned the computer fan for switching that is all but I did not figure or read the magnets on the blades and reed switch to the relay.
I cannot really suggest to you anything special, if you wish to help the capacitor by an external supply, so be it, Tito wrote precharged caps, maybe you can increase the precharge voltage to 20 or 30V DC in the capacitors or maybe higher and see how they discharge by the relay switching.  To do this correctly so that the biggest bemf spikes could be received back from coils, you have to know the coils L/R time constant and adjust the control pulse of a MOSFET switch to be as wide as that, this way at least you have done the best to be able to recover the most from an input pulse you take out from the capacitor.
So if you use a relay it has to have a normally open and a normally closed contacts and somehow you have to switch it at a variable speed, of course there is an upper limit for the speed due to the mechanical inertia of the contacts.  An 555 timer or any other low speed switcher (astable multivibrator etc ) would be good.
For a load, a 12V/ 1 - 2W lamp or similar would be good I think.
Gyula
Quote from: totoalas on February 05, 2013, 09:21:46 AM
Hi gyula
Yes this is my idea
gyulasun
Quote from: Neo-X on February 05, 2013, 09:04:12 AM
Who's doing replication? I like to test titos circuit but i have no materials needed for replication. :(
Here is the post where I show a possible schematic, Tito said it is good but needs some refinements...
http://www.overunity.com/6763/energy-amplification/msg352107/#msg352107
In that post I mention the needed components, the coils are a big questions whether they should be Tesla bifilar pancake coils or some other kind would also be good, this is not yet clear,   I suggested using ferrite E cores, or potcores, the usefullness will turn out, no guarantie... I am aware of two builders at the moment.
rgds, Gyula
totoalas
Thanks gyula for the support
I have a printer power supply 30 v dc....  pre charged the cap  as tito says. lot of options....
ur correct on the relays    one no / nc relay    ... think might need a double pole switch  to isolate the nc from the start sequence in stop mode so as not not to short/ discharged  in a off steady state.....this switch is together with the pulser button .....
Can use a dimmer switch for the fan speed ,,,,,,
I will dig  my induction cooker 12 v fan for this set up   using dime size neodyne magnets and reed switch
my hands are little bit numb due to to the recycled current clamp coil wires I used in this set up....
tomorrow is another day.....  nice result from cc
totoalas :)
romerouk
