ENERGY AMPLIFICATION
bolt
The "secret" is in the transformer design  which can NOT be operated as a normal transformer.  Circuit requires sharp DC pulses into a "special" transformer  which operates in  Assymetric mode.
It is true a spark gap is not required in modern day circuits as we have diodes, fets and scrs etc.
There are many ways to achieve  this  eg  Bifiilar coils,  Phase cancelling coils,  Bucking coils and shorting coils. Most of this provide a very large SOURCE to LOAD isolation factor which allows the load  energy  kick to grow as it attempts to QUENCH the source kick signal. The source DC pulse is converted to a series of pulses where the summation of energy provided to the load is greater than the source. Some of this can be tapped and LOOPED.  Other methods include alternate flux paths to break the magnetic symmetry as per FLYNN or use a core gap, magnetic shunts, or biased magnetic cores using neos.
The greater the SOURCE to LOAD isolation where BEMF is suppressed the greater the COP.  You will never see a COP > 1 in standard transformer operation now matter how you pulse it. or switch it.  Its well known that simple BUCK and BOOST circuits typical 83% as PC supplies can reach >97% in syncronous double switched mode.  This is proof it is NOT in the switching time or type of pulse circuit to get a COP > 1.
You need to look at MEGS etc and typical of Assymetric transformer circuits should give a COP around 3 to 5 BUT remember stages can be cascaded!!
The free electrons are best gathered from the ground but can be airbourne.   This is based on standard Tesla, Don Smith and Kapanadze technology.
Neo-X
ok, i already told this example
a long time ago. a doctor is hitting the knee
then the knee automatically
make a kick is it not?, then a
little addition of energy for hitting makes a strong
automatic kick is it not?. now its up to you then to
make a choice for a knee you
want, big, bigger or biggest
kicking knee but just the
same constant hitting in a
point you want. it should be an automatic
jetmatic eucolytic and add
some latik para masarap ang
kalamay hahahhahahahhha lol Maglalatik
Tito L. Oracion
--- End quote ---
Nd ako mahilig sa tikoy pero mahilig ako sa kalamay :D
Maybe I should act now and not waste my time here. I like to start experimenting but i have no materials needed. I have no high voltage capacitor and big solid copper coil. Maybe i should construct a homemade high voltage capacitor and use stranded copper coil instead of solid?
crazycut06
Hi Neo-X,
You can go to your local scrapyard or junkshops to get the parts for experiments with low costs, like you can get caps and copper wire from old tv sets (like i do) or from microwave ovens etc....
kEhYo77
Hi.
I've come across this research paper and the results speak for themselves.
Osamu Ide - Increased voltage phenomenon in a resonance circuit of unconventional magnetic configuration
Parametric resonance and opposing magnetic poles of two facing electromagnets, that's the KEY!
It would explain Magnacoaster's and Romero's devices quite well...
I think I'll build a setup for this :D
Cheers!
kEhYo
totoalas
energy amplification pt 1 080113  yt totoalas
using gyulas tito circuit 3  in red box for test
using e core
bifilar connected in series with 12 v relay and switch contact by flyswatter  no cap
loadis connected to led
l4 is in series with water tap then  is either connected to pos or neg of 33000 uf 63v dc
L3 cap is being charged
more testto come
ps check mopozco comment about titos circuit in yt tros aviso coil shortening
totoalas
