ENERGY AMPLIFICATION
0 Members and 114 Guests are viewing this topic.
totoalas
Energy amplification pt2 in/out going up yt  toto alas
Ch
Tito check this out  hehehe
Thanks to gyula and romerouk
gyulasun
Hi totoalas,
In Part 2, without the use of  the ring magnet the voltages do not increase in the caps?
Try to remove the magnet BUT do not fully attach the E core parts together, leave a variable air gap and fine tune the (gap) distance to see how the voltages change. USe thick card board or wood or plastic pieces for keeping the distance between the E cores controllable and defineable.
One more question: in PArt 2, do you use earth ground? If yes, where do you connect it?
When you go the China, try to buy an L meter... LOL
Gyula
gyulasun
Hi Romero,
Thanks and what I have written or suggested to folks here so far as pieces of advice was based on my past experience, unfortunately nowadays I cannot do so much tests personally like some years ago. So regarding the usage of different conductors like Alu or iron wire etc is to be explored.
Best regards,
Gyula
Quote from: romerouk on February 07, 2013, 07:06:29 PM
@gyulasun
Hi,
I totally agree with you that a controlled ON time will make Mosfets favourites in this application but that is not all to be considered. Must use multiple mosfets in parallel to get close to the sharp ON/OFF time that thyristors are handling very easy. My suggestions are based on my experiments with higher voltage where before switching to thyristors I have burnet so many mosfets and IGBT's and the results now are almost comparable to a spark gap. In my experiments I found that a very sharp complete discharge of a capacitor is the real deal, I never care about what books are saying, I always try to see with my own eyes.
The best way to test and calculate coil and the capacitor to be used in this experiment is to just use 2 mechanical switches. Charge cap 1 then discharge it and watch voltage in the second cap. Do that slowly repeating and making notes of what you changed. It might look very basic but that helped me many times.
Anyone considered using a different type of conductor? not just ordinary copper?
Anyone tried doped conductors? if not please do, you will see a big difference.
Regards,
Romero
crazycut06
That's a good start  :)  question? In video #2, Are you using the fly swatter as input power? Pulsing the primary coil?
totoalas
Quote from: gyulasun on February 08, 2013, 06:11:49 AM
Hi totoalas,
Gyula
thick cardboard is conducting on the load
without half of the e core or load  the voltage is is rising on the input and output caps and also without magnets when i lifted the other half top e core
i was shocked again same feeling if you touch a 220 v live wire
l meter specs please
conclusion
using water tap pipe as earth  on pos or neg of input c1
spark gap using 12v relayy no contact
fly swatter no contact output for s1
both input and output caps are charging
