ENERGY AMPLIFICATION
0 Members and 67 Guests are viewing this topic.
totoalas
latest test
no L4 coil and earth connected to water pipe  load connected
same fast charging   on the c1 and c2
so the arc is the key    got it  lol
now we can harness the arc or plasma to kick start the charging
will post the video later
gyulasun
Quote from: totoalas on February 08, 2013, 07:16:54 AM
can shop only next week for the L meter as all shops are close starting tomorrow for chinese new year
Here is a better and cheaper ebay offer (open only after February 17)  on LC meter, type LC100-A :
http://www.ebay.com/itm/LC100-A-Digital-LCD-High-Precision-Inductance-Capacitance-L-C-Multimeter-Meter-/300821886212?pt=LH_DefaultDomain_0&hash=item460a61b504
Notice that the A suffix (i.e. LC100-A as in the above link) has the extended measuring range for capacitors up to 100 milliFarad i.e. 100.000 uF.    (IF you find LC100-S   i.e. with S suffix, it measures caps to 10 uF only. and if you are offered LC100 without any suffix then it measures caps up to 1uF only...)
The inductance measurement range starts from less than 1uH and goes up to 100 Henry so has a very wide range.
Here you can see that a real  LC100-A  type LC meter has 4 color buttons to select high or low measurement ranges etc while the other LC100 types has only 2 or 3 color buttons:
http://www.goodluckbuy.com/images/detailed_images2/fe0c4b9cca69e8263cee0e05441e7567.jpg
The DC power is +5V and can be run from the USB output of a PC (mini USB cable is normally included).
Gyula
totoalas
i remember i saw same model in one of the shop  will see nest week
totoalas
arc/plasma charger 090213  yt  toto alas
earth from water pipe and series L4 coil removed and both caps still charging
spark changed to plasma  when earth is connected to pos or neg of input cap
totoalas
Charge conserving capacitive spring  post no 254 page 9 by supercavitationistic   energetic forum
a good explanation of what tito is saying
