ENERGY AMPLIFICATION
0 Members and 58 Guests are viewing this topic.
onthecuttingedge2005
Quote from: Tito L. Oracion on August 27, 2009, 11:57:02 PM
oic i thought you are experimenting about explosion amplifier  ;D
Hi Tito.
that's funny, no the idea is that photons and electrons go hand and hand, if a LASER amplifier medium is used the electrons pump out twice as many photons into greater amount of photo pressure, the idea is to trap this photo pressure in a photo amplifying medium. then by controlling the leakage of the photons one can leak a specific amount of stored light into a full band gap solar cell array for the production of power.
it's more complicated than what I just specified but it's a reasonable short explanation for starters.
cooled Sodium Gas Atoms can slow down light to a complete stop but we're not looking to stop it just slow it down to a really ultra slow crawl via temperature control of the sodium gas atoms. this would allow photo pressure to build up into the medium for more efficient Photovoltaic reactions and photo amplification due to the over excess of photons within the medium.
this is where the Sodium Silicate comes in, if it can do the same thing then this makes the procedure much easier than using cooled Sodium Gas.
Try cooling the full Sodium Silicate crystal first as a whole then try it again with crushed and ground Sodium Silicates to see if optical trapping occurs, if it does then we go to the next step, the band gap of the sodium silicate changes according to the grade of the ground up crystal. this also occurs in ground silicon itself.
Photon amplification of the exited LASED electrons results in Photon OU. 1 photon turns into 2 then 4 then 8 then 16 then 32 photons and on.
Jerry ;)
Tito L. Oracion
Quote from: onthecuttingedge2005 on August 28, 2009, 12:23:25 AM
Hi Tito.
Jerry ;)
wow! that's interesting. i pray for your success  be careful bye .  :)
markdansie
Hi Tito,
with all great respect to you and the needs of your family, I can understand your fustration with your government. There are two solutions if you say what you have is real.
1. post the design and tech specification on the internet and give it to humanity.
2. find another country or investment group that will take your project forward.
This is only my opinion and I express it with respect to you.
i think many people here would appreciate the results you have achieved in regards to input and out put and how you measured them. This does not require you to specify you technical details which can remain hidden.
Kind Regards
mark
stprue
Quote from: Tito L. Oracion on August 27, 2009, 11:02:55 PM
hi ac
i understand that also what you mean, currently my situation is not good and i don't know whose to trust and i need to earn money for my three children, i believe God will understand me also.
sorry guys
A tip to all of you: study the real process or the real thing that is happening when charging many caps of at least 10K uf in high voltage dc and discharging it sequencially in a coil with secondary! the only secret here is how you connect the caps from battery and coil efficiently! thats it you have it.
offcourse you pulse it!
otits
Are you charging them all at the same time and then using something along the lines of a led chaser circuit for discharging?  ...and probably some back into the coil and some caps for useable energy?
Tito L. Oracion
Quote from: stprue on August 28, 2009, 08:57:00 AM
well, partly you are correct but there is still missing, the technique of using other coil making a kick without using any current from the input and that makes excess or unlimited energy. and i got this technique in henderson file.
my device is a combination of tom bearden, henderson and bedini.
sorry i'll be busy now, i cannot respond always.
God bless
otits
