ENERGY AMPLIFICATION
0 Members and 129 Guests are viewing this topic.
Neo-X
@totoalas
Tae na nilalanggam ihi ko mapupu2lan yata ako ng paa.. Tnx theguru2you lol :)
forest
Energy amplification by resonant rise. Always were here in resonant circuits. We are blind like those saying " there is no gain in this bell sound". Remember what Tesla said about bell....
Really the only issue is to keep dipole not destroyed and tap power not disturbing it...
Magluvin
Quote from: forest on February 16, 2013, 08:04:02 AM
Lets put the Tesla 'tapper' device that shook a building into resonance for example.
If we made a solid base to mount a length of flat spring steel, with a weight on top that moved like a pendulum, but not pivoting at the bottom, but mounted solid so the the spring takes on the left and right actions, and we have a tapper device to make it move, where on the length of the spring would we want our tapper? The bottom, middle or top?
Well Tesla used it at or near the base of the building. So we should follow suite.
We set the spring pen in motion to count the freq of movement, this way we can set our tapper to be in sync. We stop the pen, turn on the tapper and we wait. lol But it should get the thing moving. The tapper could be electronic, with a coil that pulses a magnet at the base, and use a sensor to detect what position the pen is in for the next tap automatically. I suppose like a pulse motor.
So now we can recreate Teslas demonstration. This has been done with pendulum toys and such, but Im talking something closer to what Tesla did. A normal pen uses weight as the reset force, where here we are using a spring, of which the building must have had some.
Once we get it going well and as efficiently as possible, then we can start trying to tap into that swing of the weight going back and forth.
Now, how and where on the building can we collect the energy? And is it more than the input? :o ;D
Mags
totoalas
Aviso once quoted
"at the peak voltage where the surge occur in coil shorting  thats the time to capture and multiply a million times"
thats why he went to peswiki for the cotrol circuit development
as for tito s  idea
instead of  radiant energy    he used battery as source   pc fan for control and maintain the energy in the primary while in resonant mode for the secondary ( my interpretation)
I really would like this experiment to proceed ....  missing only are the zener and the motivation from others that hang on to this thread......
to die a naural cause is not acceptable   ....   you read that TITO   TEETS  ..  but  to live with a noble cause ....  im not asking too much
just a slice of the pie   .......  DIE HARD    now showing
totoalas
Hi gyula or anybody
can you please give  the size of zener diode ( part no ) that is appropirate for the tests.....(Tito circuit 3  ... should be Gyula circuit 3 for right recognition )
thanks
