ENERGY AMPLIFICATION
0 Members and 120 Guests are viewing this topic.
gyulasun
Quote from: totoalas on February 17, 2013, 06:08:40 PM
Hi gyula or anybody
can you please give  the size of zener diode ( part no ) that is appropirate for the tests.....(Tito circuit 3  ... should be Gyula circuit 3 for right recognition )
thanks
Hi totoalas,
When I showed the schematic first as per Tito's text description, I wrote that I did not include any Zener diode in the schematic because its function was not mentioned, and I noticed if Zener diode(s) are used in that description than they may be connected in parallel with C1 and C2 to limit voltage level, preventing any run-away situation.  Now we know as per Romero's kind contribution that this circuit (built as per Tito's description)  is able to run for a short time then all the initial charge is used up. This means that Zener diodes are not needed, AT LEAST not in parallel with the capacitors.  If Zeners are needed for other places in such a circuit, then the type and ratings should come after we know what task these Zeners should do.
Has someone done  switch-on time for the S1 and S2 as long as 0.5* L/R second and see how much voltage is received in C2 when preferably a few volts was consumed from C1?  Has someone increased the intial voltage in the caps  from the 10-12V level up to 40-50 Volts or higher to see how it counts? OF course this involves using higher voltage/current rated MOSFETs (or thyristors but you have to master thyristors like Romero if you use them).  Romero also mentioned the use of other wire material than copper.
These 'ramblings' are not a complain to you of course I only mean that some systematic approach should be followed if someone wishes to go ahead.
Greetings, Gyula
Dave45
Guys we must work together
If one of us has a free energy device should we post it? ??? ?
We are slaves to the dollar and energy dependance are the shackles that bind us.
I watched a vid the other day about a people in Africa their country was at war because of the oil and greed that come with it, they were displaced into a neighboring country, raiders would come and wrape there wives and cut off the ears and lips of the men.
These events and worse are being played out all over the world so if we have free energy should it be given to the world or should we hold out for money ??? ??? ??? ??? ??
You decide
For unto whomsoever much is given, of him shall be much required
totoalas
Quote from: gyulasun on February 18, 2013, 08:48:29 AM
Hi totoalas,
Greetings, Gyula
Thanks all you say are constructive and will try to digest even in a slow but sure way to meet our objective
Im just collecting info on hv pulse and just found xee2 fits into my requirement input v from 1.5 to 24 v  and can run on solar   its a jacob ladder
Ill try to make a neat circuit on a wood  i m also considering slayers latest circuit where the rf is concentrated only on the tip of the wire end
forest
Qwert
Quote from: Tito L. Oracion on February 18, 2013, 07:49:14 AM
Seeeeee
Well, I believe, to offer money to somebody to finance some drugs when the person suffers a disease, equals an equivalent of prayer or good word, nothing else; and that was the reason I did not intend to trumpet that. I did not expect any obligation, what I clearly noted. Circumstantially my wife has alike disease and I know great benefit of the drug I intended to finance. The drug is pretty expensive in the USA, but abroad can be bought for even as low as one-fifth of our price, what I use to do regularly, by Internet or by phone / mail.
