ENERGY AMPLIFICATION
0 Members and 130 Guests are viewing this topic.
crazycut06
totoalas
Magnetic bi toroid raw power  190213  yt  totoalas
this bi toroid has the following
one primary 6 strands 30 turns shorted   connected to earth ( water pipe)  and  center tap of two secondaries 30 t each
the ends of the secondaries are in parallel with the caps 33000 uf  63 v dc  not pre charged
Missing are the diodes  to charge up the caps
Using the normally open contact of flyswatter   one end is connected to the primary  and the other end Im tapping to all the parts coils magnet and caps to show the intensity of the spark  and the charging effect just placing the wire on the surface of the berryllium oxide ferrite magnet from microwave oven
Im still looking for a hv flyback to do more tests ...
this is somewhat similar to gyulas circuit   but with only one switch
Kidniken showed great details on his latest bitt video   ....  my problem is the cost   50 Renminbi each toroid core and the need to cut the other into halves
So itested the microwave oven ring magnets which is showing same results with gyulas
Either Ill settle for a pc fan switch but still missing on the hv part
In all these test   the combination of supply   pos or neg  plus earth ground   usually turns yellow spark into white or intense glow
it all confirms  peter lindermans plasma mod cant read his circuit  .....in his video   on the 555 timer.....hope somebody help me out on this
totoalas :)
totoalas
update on gyulas ckt
used a pc fan with pot neos and magnetic switch  relays
speed is too fast for the relay to energize  or my 2 amp power supply is not enough for the 12v coil
also must use two separate n o contact relays if caps to stay in precharged state no choice but the 555 timer is the only way
