ENERGY AMPLIFICATION
0 Members and 65 Guests are viewing this topic.
Qwert
I guess I have solved one Tito's secret. Sometime in the past Tito mentioned that in his invention he uses a solution found in Tesla's Ozone Patent. Till now nobody seems to get, what exactly Tito meant.
In the post under this link
http://www.overunity.com/6734/real-ou-effect-to-share-with-everyone/msg206661/#msg206661
Tito gives an answer to a guy (FatChance!!!) who states a specific point of view:
"Simply because there is no overunity to be had from discharging a capacitor into a coil.
What you believe as overunity, is actually performed in everyday modern electronic devices.
I'm talking about the switched power supply. This is discharging a capacitor into a coil and
then stores the coil Bemf in the output capacitor. And there is no overunity what-so-ever.
In the best case, the switched power supply can reach 99% efficiency when using the best
components available, aka low ESR capacitors, LOW Rdson mosfets and the finest coils with
low resistance, very low hysteresis and eddy current losses.
All cases showing overunity while discharging coils or capacitors is always underunity.
Any overunity reports is just a clear sign of a person lacking the necessary measurement skills.
Tito's answer: "hi FC
try to study the ozone patent and your belief may be change ok
I guess, Tito's essence starts at about 85 verse, page 1 of the patent original text (patent # 568177):
"Around the controller is formed a circuit of low self-induction, which includes a condenser L and the primary M of a transformer. The circuit including the motor is of relatively high self-induction, and this property is imparted to it by the coils of the motor, or, when these are not sufficient, by the addition of suitable choking-coils, so that at each break of the motor-circuit a current of high electromotive force will be developed for charging the condenser, which may therefore be small and inexpensive. The condenser discharges through the circuit which is completed through the brushes G K and the controller H, and since the self-induction of this circuit, as well as the capacity of the condenser itself, may be given practically any desired value the frequency of the discharge-current may be adjusted at will.  The potential of the high-frequency discharge-current is raised by a secondary coil N in inductive relation to the primary M."
Here is another link with relative subject:
http://www.overunity.com/7941/tommey-reeds-pulse-generator-output-test-update/msg197620/#msg197620
" Hi tom good day
how did you made your PWM?
i mean how could it last the switching on and off?
And answer, just two posts below:
Otits,
The pulse generator is design so the kick back effect wont destroy the mosfet.
Think of one way valves, power goes in, and the kick back (or say fly back), goes into the cap.
If you add a diode to a coil, the fly back is shorted out to prevent the mosfet from being zap from the high voltage kick back.
I use 4 diodes for that reason, but add a cap into the center of the 2 diodes to collect the back emf.
Tom.
Also, I found very important this link (innovation_station):
http://www.overunity.com/7513/creating-free-energy-out-of-collapsing-magnetic-field/msg184532/#msg184532
go and read it.
and this
http://www.overunity.com/6763/energy-amplification/msg202694/#msg202694
"what i'm saying is, as i am studying tesla's different kinds of patent, i concentrated most in this patents:
a) U.S. Patent 0,568,178 -
b) U.S. Patent 0,568,179 -
c) U.S. Patent 0,568,180 -
d) U.S. Patent 0,577,670 -
i've read also the teslas interview what forest's is posting in this subject
and i come up in a very simple solution when i combine bearden and bedini's technology.
sorry buddy i cannot give my circuit yet but  i'm telling you the truth.
the only thing that i did not give is the arrangement of the circuit. ok its an rlc.
DO YOU KNOW THAT USING THIS METHOD CAN GENERATE KLWATT FROM A 1.5 VOLTS!
ofcource sub-staging technique must be used ok. "
I'm just reading these patents; right now I can only say that patent # 568178 is about setting resonance in a circuit.
I'm continuing to track Tito.
totoalas
HV DC PLASMA LVHV AC PULSE CHARGER 210213   yt  totoalas
http://youtu.be/sxXa1ZxHAxs
Using transfomer    input and output  terminal as LV HV ac source   one can be used  for loop to pulse circuit  and the other hv for pulse charging   Flyswatter 4,5 v dc input  and dc plasma output   with water tap faucet as earth    .Spark is changed to plasma  when earthed
Qwert
At reply # 2746 ( http://www.overunity.com/6763/energy-amplification/msg352052/#msg352052 ) Tito said  "just use a computer fan for switching and just for simplicity." Can somebody explain why computer fan for switching?
totoalas
Quote from: Qwert on March 02, 2013, 06:31:10 PM
hi qwert
my understanding for the fan using neo magnet on the blades and reed switch  for fast switching of two cols alternatively....instead of 555 timer and fan is readily available
totoalas
http://youtu.be/oe9VbSvthAY
ENERGY AMPLIFICATION PY 3 JACOBS LADDER 030313
