ENERGY AMPLIFICATION
0 Members and 244 Guests are viewing this topic.
Magluvin
Quote from: romerouk on March 15, 2013, 03:38:20 AM
@Magluvin
''Is there an advantage to having 1kwh at 100v than 10kwh at 10v? Where is the OU?''
It is a big advantage in running at higher voltage, first because power from the 'air' is in that range then to create a resonant system with high voltage will require small value capacitors that means cheaper comparing with a resonant system running at 10v where we will need large capacitance. Tuning and stability is much better with high voltage.
''RLC. How do we derive more power from an RLC without killing the oscillation 'and' get more out than in?? ''
Should run the main coil(sender) with sharp pulses and not in resonance and larger gap in between pulses, the resonance comes into action after each pulse and in between the main and output coil or only in the output coil.
Romero
Hey Romero.
How have you been? :)
I get that to produce an amount of energy to a primary or a load that at lower voltages the cap must be big compared to high voltage. Also it takes less current at high voltage to produce a similar power output.
I also understand that using very short pulses helps to let the secondary do its thing without the primary affecting it, because the primary was only on for a minute amount of time, never the less, a powerful event. But if the secondary is ringing at resonance, how long will that last into a load, and does it add up to more power than 'the powerful event' pulse? ;)
Thanks
Mags
totoalas
Quote from: Kev on March 29, 2013, 12:10:24 AM
Hi Tito!
I'm going to watch every single video
Will post comments later about it  8)
Kevin
Hi Tito!
Tito tits one video is enough   which one you think is related to your invention   im still watching 10 commandments by richard burton   lol
Kevin
Dave45
good to see you back  8)
brother  ;D
