ENERGY AMPLIFICATION
0 Members and 82 Guests are viewing this topic.
Dave45
This is with 12 dc, Im going to freeze it with ac soon.
Look at the Tesla egg of columbus, this is the field that we need to collect.
http://www.youtube.com/watch?v=Ec4u4BfS4tE
Magluvin
Hey Dave
Very cool with the ice. ;)
So this is a spinning field?
How do we collect from it? We are used to collecting expanding and contracting, or also controlling where a strong field will be from where it was. But if the field is spinning, we dont have field lines 'crossing' wires.
Have you done any of the ice visuals with just a magnet suspended?
Thanks
Mags
Dave45
Hey Mags
I have not tried to collect from this particular coil yet, still studying. This is done with 12 volts dc, the two triangle coils are connected in series as soon as it thaws Im going to hook it up with ac and let it freeze.
I have used a solenoid type coil without a core and an aluminum plate under the coil and collected from the plate, I will eventually do the same with this coil.
Iv studied alot of devices and normal induction just doesnt seem to do the trick, the plan is to create a energy well, a sink.
I hope to get more people interested and experimenting with the ice I have found some very unusual qualitys that need to be researched more, you folks have alot more experience than me.
Use bottled drinking water it works the best I have tried about everything to get a clear view.
This is the setup I used to collect from the solenoid, I will try this coil soon.
Magluvin
Quote from: Dave45 on May 02, 2013, 10:10:02 PM
But what is collected to the plate? And in reference to what?
Like wouldnt 2 plates be necessary in order to have a - and + to work with?
Im just trying to get to the meat of your ideas. Like was said earlier, ok we see the coil, but what does it do and how do we do it? ;)   So by saying 1 plate, is it just to pull energy into the coil or to get from the coil? The reason I say is you said the plate is for collecting, but in the drawing it looks like it is connected to ground.
So if the plate is for introducing more energy into the system, what energy are we talking about or dealing with? Are we pulling electrons from the ground into the circuit? Is the water only there for the freezing visual purposes, or is it acting like a dielectric between the coil and plate?
Mags
Dave45
Electricity goes to ground, Iv wired plenty of houses the electricity comes in as 220 volts on two legs each leg is separated, 110 volts and runs to ground with a resistive or inductive load in between.
The idea is to freeze the system running to ground no resistance then a resistance can be placed between the plate and ground.
