ENERGY AMPLIFICATION
0 Members and 69 Guests are viewing this topic.
totoalas
Quote from: Tito L. Oracion on September 01, 2013, 07:36:12 PM
oh! :o  i didn't notice it. how about you?  ;)
don't worry beef is available.  ;D
i don't have plan yet for coming out, like what i always said i'm a peaceful man  ;)  man of fish, like man of steel  ;D
at least ur constant with ur talk the walk and not wack talky   salute to that bro
Tito L. Oracion
Quote from: totoalas on September 01, 2013, 08:03:04 PM
Well, i'm just being truthful to everyone and that is truth or throat. :D
pre bigyan mo nga ako ng magandang idea para pagkakitaan ito ng mabilis at sigurado na di magiging delikado ang pamilya o buhay ko.
kahit papano di naman basta basta tong nadiskubri ko e, syempre gusto ko rin kumita. at yon ang di naiintindihan  ng mga kasama natin dito. gusto nila bigay ko lahat e, anu sila siniswerti.  ;D
Talong taon din ang ginugol ko sa pag reresearch ko dito kahit papano.  :)
Ps. alam mo bang napolis si napoles?. corny no? hehehehheehh
Tito L. Oracion
By the highway.
i just have a doubt about using hho. because water is accumulating inside the engine there should have a modification about that, cause water is mixing with the oil and if that happens off course heat will rise and your engine will be destroyed. :)
ok! here is my explanation.
The result of the explosion of hho is water right? then some will go outside but some will accumulate inside the crank case at the bottom part of it and incidentally our oil pump will suck at the bottom part of the crank case where oil resides and since oil float at the water then there were a time that water will grow and problem will occur into thinking that water will be use as oil by the engine. got it?  8)
And that's truth or throat  ;D
did you saw that everyone?  8)   ;)   ;D
Noicaro L. Otit  ;D
Magluvin
Quote from: Tito L. Oracion on September 01, 2013, 11:41:15 PM
By the highway.
Burning gasoline produces water also, along with other things. ;) Ever see water coming from a tail pipe? ;) Some people are spraying water mist into the intake for more power output. So I dont think there would be much harm. ;D Just change the oil more frequently if need be.
Mags
Magluvin
Quote from: Magluvin on September 02, 2013, 12:15:02 AM
Mags
If you are having a problem with water in the oil, maybe your piston rings are leaking. Also steam can be a problem in the gas created in the cell. I see guys out there that use a bubbler which may reduce the steam, also a water separator, like used in compressed air lines for painting and such. Also, if perhaps all the fuel, hho, is not burning, which would seem improbable, but anything is possible, then the H and the H and the O on their own could affect parts of the engine badly.
Mags
