ENERGY AMPLIFICATION
0 Members and 54 Guests are viewing this topic.
forest
stupify12
Understood, but I'm working on another ball of ice method, or actually it is a Titanic version  ha ha  ;D ;D ;D  You make a kick and let it flow and flow and flow and kick iceberg which is now flowing into Titanic  ;D ;D ;D ;D ;D ;D ;D [size=78%]....[/size]
Tito L. Oracion
@forest
              as i told everyone we are not limited to one design ok, we are free. The important thing is you must knew the working engine. :)
        Be careful buddy i know what you mean. that's very dangerous. :) :'(
it can strike very fast like lightning. :)   :(
insulate your self ok?, be safe. :)
Cause without you, there will be flood in the city. like in the Philippines ;D
@stuffynose  ;D
Source is not a big deal anymore okay.  ;)  let say we use the antenna source, the style of coil should be according to what it needs ok,
now if battery, of course it should depends on how you can use the full strength of the certain battery volts and its amp.  8)
in that way, what i mean a say is that it always  depends on the source how you make your primary phases of coils. hope you get it. :-\   ???
it always need matching technique and balance. and timing is not anymore big deal also here but still included.  ???
let say for example a child or a baby cannot chew foods that an adult can. ;)
Well, one time i made a design that needs a battery for just a starter, and if you will not remove it, it is being charge. so after start you remove it and that's it. it should stand itself.  ;)  and that design falls under sm, hubbard , bearden design. just caps ok 8)
and if you want antenna you really need at least two to three phase or i mean stage or whatever you call it. :D
BUT the best for me is the DC amplification, believe me. ;)   :)
Thank you, hope i made a little help to everyone. :-*
me and always me the teaser of everybody ototits.  ;D ;D ;D ;D ;D ;D ;D  i mean teacher ;D
God bless everyone. :)
I HOPE I FREED EVERY ONES THINKING IN THE BOX, CAUSE THAT IS MY PRIMARY PURPOSE HERE AND THAT IS TO MAKE YOU FREE. ;)
LOVE YOU EVERYONE.  :-*
;D OTOTITS  ;D
Dave45
truesearch
@Dave45:
Very nice!!
Are you planning to freeze it in water? If you do, please share a photo of the results so we can visualize the magnetic field produced.
truesearch
totoalas
Sept 5, 2011
Zilano
parallel or series????? resonance!
[/font][/b]
An electromagnets magnetic field strength is
determined
solely (without changing the ferromagnetic core
material) by the number of turns in its winding times
the
current measured in amps flowing thru it. With that in
mind consider the difference between serial resonance
and anti-resonance (below).
[/font][/size][/color][/font][/size][/color][/font][/size][/color]
Series LC circuit:
[/font][/size][/color][/font][/size][/color][/font][/size][/color][/b]
Resonance = input current is
maximum
at resonance; Current thru drive coil windings
is
maximum
Parallel LC circuit:
Parallel Resonance/Anti-resonance
= input current is
minimum
at anti-resonance; Current
thru drive coil windings is
maximum
Now, if you were a design engineer after the maximum
magnetic field strength for the least input power,
which
circuit would you use?
[/font][/size][/color][/font][/size][/color][/font][/size][/color]answer: parallel of course!
