ENERGY AMPLIFICATION
stupify12
Tol Otits ;)
The ping pong TECH of your's is your own design that has surpass previous Free Energy Mad Scientist ;D ;D. Thank you so much for giving us clues and tips.
But still im having problems of switching this ping pong Otits Tech, It can easily burn crispy our solid state Field Effect Transistor or Mosfet. Any suggestion for a good switching will be much appreciated. Are you using now a rotating solid contact disc switching? I also read from some of your post , that you are using some logic IC like 78xx for timing and balance of the sequence that will happen in the system. 78xx IC logic or decade counter maybe flipflop,?, then you are now using solid state switching with durable electronics?
Tol, I think you have already reach the top, but for me and some that has recently understand this technology we are still starting to swing the flow to vibrate this free energy. So I am begging for new hints on the technical instruments, parts, or specification of the transformer coil like the ratio of primary and secondary- I think that is too much for request but I will be gratefull if you could answer us even in a one sentence. ;D ::)
@ Everyone, If you have a schematic or pictures of Historic Free Energy Devices that you think is true, kindly post it here so that we can discuss, develop, and modify it to suit on our newly found technology that comes from outside the box ;D ;D ;D ;D
stupifymeow ::) ::)
Tito L. Oracion
Quote from: stupify12 on September 25, 2013, 11:55:21 PM
Tol Otits ;)
The ping pong TECH of your's is your own design that has surpass previous Free Energy Mad Scientist ;D ;D . Thank you so much for giving us clues and tips.
stupifymeow ::) ::)
Hi everyday  ;D
Well, that kind of humble attitude really make my hands to answer even i don't want to.  :)
in my experience the customize switching is still the one that last longer, try some hinges and carbon but do it in more exotic way ok  :D
i also tried some electronics but just for low voltage only, mean the half part of course.
electronics today are really good especially in my latest discovery of DC amplification, you can use them to make full control and you can dictate lots of rules.
i used 78xx also as current amplifier.
well, i do not consider my self reached the top cause i am not stoping in studying for there is always new everyday.  :)
well, bifilar is the best in primary, cause it doubles the effect of the input.  ;) ;D
The design should always be simple as it can be, cause in the time of tesla he is just limited for electronic components ok.  ;)
I BELEIVE I HAVE GIVEN ALL NECESSARY TOOLS TO USE, ONLY SOME PART OF ARRANGEMENT IS MISSING. ;D
OTIOTS  ;D
stupify12
Tol Otits,
            Thank you very much for that clarification. I know how exactly the engine(TITANIC ;D) function on this set up. There is nothing MISSING on behalf of me, we all know that an engine will not function if there is even a small parts left to attach.. Right ;D ;D? Some problems arise like the question I have asked above. Then I will go with the HINGES?=(Commutator?), Im not really sure what you mean of HINGES?
For the Transformer part bifilar is indeed a better primary than single wire.Is the MAGIC COIL has the same length with the secondary coil in your design, what do you think that will work best, the same length or much longer than the secondary?
I have my focus on DC Amplification of Carloz Benitez 4 Battery Switch this guy has combine all the fame invention of Nikola Tesla into one set up with a promising result.
Again.. Thank you very much for that answer Bro Otits. ;)
::)stupifymeow 8) 8)
Quote from: Tito L. Oracion on September 26, 2013, 09:51:57 PM
Hi everyday  ;D
OTIOTS  ;D
Tito L. Oracion
Quote from: stupify12 on September 26, 2013, 10:33:56 PM
Tol Otits,
            Thank you very much for that clarification. I know how exactly the engine(TITANIC ;D ) function on this set up. There is nothing MISSING on behalf of me, we all know that an engine will not function if there is even a small parts left to attach.. Right ;D ;D ? Some problems arise like the question I have asked above. Then I will go with the HINGES?=(Commutator?), Im not really sure what you mean of HINGES?
I am happy now for there is someone understand what i mean. :) ;)
Its actually an incident combination of the two multiply by 3. ;D  sorry for the exotic formula.  ;D
The longer wire will add up strength of the field, but it works best if you make the secondary is inside of effect strenght of the primary so that the extra wire will not become a friction to the flow. and from there you should be doing a large spark which is what we really is aiming.
and don't forget to add some KAL(SO4)2.12H2O at the HV portion.  8) :)
and that is the balance i am saying.  ;)
That's all i can give buddy. be carefull.  ;)
note1: it is the friction that makes things hot. avoid overheat ok.  ;)
         That is really the main reason why successful design is perfect.  ???
          There should have heat but not overheat ok  ;)
         Lalo na anghit  ;D
note2: if you can afford or get some radium then why not. ;)
           This is really good in ionization process. ;)
otitots  ;D
totoalas
Quote from: Tito L. Oracion on September 27, 2013, 02:19:58 AM
         Lalo na anghit  ;D
otitots  ;D
http://youtu.be/PdMR1jSH9Dc
TITO OTITS   NONGNI
d naman siguro aabot ng PHP 1 M
yung katulad sa yo   na MAY RING MY BELL
AND GONNNA KNOCK ON UR DOOR  HEHEHE
