ENERGY AMPLIFICATION
0 Members and 74 Guests are viewing this topic.
Bob Smith
I hope that nobody here fells himself offended by my posts
cause I am actually not in a calm position and have to think and to do many thinks
to reorganize my life and the life from my fathers family
after he,my father,died on 10/05/2013  !
I re-/searched for the common sense and the common science in and for the definition of
energy,force,electricity,work and power and their source !
I try ever to describe the meaning/opinion/view in a kindly(also childly) manner so
that unskilled people can or should understand the kinetics by my neuronal view and
if possible as open source publication with description and images/drawings or
with links to commercial workpieces which could be seen as an idea aequivalent !
I am a free man with corporal dependences but less dependant by mention of ideologies;exploring and execute good ideas- not hidden and not alone !
Pardon, if anybody understood me wrong
We will find naturekind and also our mankind -the roots -that has been the route
the Neumann man-machine( up to the naturemachine) with the Kybernetik tools
We will have the tools to convert/compress or invert/dissolve energy to material and material to energy -for digitizing/scanning and archivate the "FORMAT-genom"
                                    Ap-/Re-plicator
                       the 4D-lab to the 4D-factory
                   lithography by Prism(a) and Spectrum     Goethe/von Braun/Raman
Images are 2-dimensional,calm :translate(translatory) the direction scalar/vectorial
by Flemming and Lenz-Rule: with your hand and fingers,use your own body
                                  give  X and Y the flow ,chromosom dance
Sincerely
              CdL
p.s.: release
       solar/thermovoltaic cell                             = 1 condensator(Transistor)
to
       solar/thermovotaic cell/s-array/battery     =multiple condensator(Transistors)
                                                 and now
reread/study the Gyula Tesla-article :amplifying by Kaskade/cascade/array
                                       TRANSDUCER
(of what ? Energy from Neurophone/Patrick Flanagan  -view :Fullers Teleology)
From Gyulas offered Tesla-article:
When the currents are rapidly varying in strength, quite different phenomena, often unexpected, present themselves, and quite different laws hold good, which even now have not been determined as fully as is desirable, though through the work, principally, of English scientists, enough knowledge has been gained on the subject to enable us to treat simple cases which now present themselves in daily practice.[/size]
Teslas partner whose have had to translate/determinate his thinking to mathematical context has not been english cause it was a german named Karl(Charles) Steinmetz.
What happened after their partner-ship solution ?
With Mr.Steinmetz and  with Mr.Tesla ?
http://en.wikipedia.org/wiki/Charles_Proteus_Steinmetz
Probably he,Charles Steinmetz, has determinated some searched answers !
forest
You still here ?  ;) ;D ;D ;D   don't you think Tesla texts are strange , like having something removed or messed with or encoded ? I think Dan Brown next book will be about Tesla and free energy mystery.....  :o
" If the relation between these is such, that at the frequency used they annul each other, that is, have such values as to satisfy the condition of resonance, and the greatest quantity of electricity is made to flow through the external circuit, then the best result is obtained."
Strange indeed.... the answer you saw on this page  ::)
Each coil (5) (6) is performed in a carriage with nucleus of cylindrical or rectangular (15) shape, air nucleus, and two lateral covers. The coil system(16) consists of two copper tapes, separated by a dielectric of macrofol, " an insulator tape". They are simultaneously rolled up m 397 spires where are connected, in upper extremity of one of the tapes a feed cable and m the lower extremity of the other tape another feed cable. Closed the coiled process is vulcanized with epoxide resin, which gives mechanical resistance, insulation and allows its utilization m high humidity level. After this phase, a paramagnetic ( 17) nucleus is inserted inside the coil where the upper side has a width equal to the general body and the other extremity is screwed down to allow its fixing. All this system is controlled by a module that allows the variation of the polarization, constructed with materials and components existing on the market and already attested. The conjugation of several potentialities and applications of these components allow it a believable and linear behaviour in the control of the referred system. The technical range of this system stands in the present electromagnetic spectre, nevertheless is different owing the coils not having a standard behaviour in relation to the power consumption, they have not internal resistance, placing several questions of theoretical quality: According to the ohm's formula R=V/ I. With R=O and having a tension V on the coil, appear us the first theoretical difficulty to solve this equation, impossibility or irresolution. According to the Joule's formula w=I<2>xR, appears the same impossibility. According to Weber's formula Um= [psi]xRm we see that the magnetic tension (Um) is the result of the multiplication of phi ([phi]) by the reluctance (Rm) . We go on with the same impossibility. According to Lenz's formula [Delta](cos[psi])/[Delta]t we obtain that the induced electro-motive power (Ei) is the result of the division of the rate of the cosine of phi ([Delta]cos[phi]) by time variation. As cosine of phi is equal to zero, the irresolution is maintained. In practice submitted to several measures and tests we obtained a residual power consumption of 6 mA resulting more from cable feed then coil power consumption. The value of phi ([psi]) stands unaltered and equal to zero. Practical situation without theoretical justification known. [/font]
                                Not-either the left,not-or the right
  it is the middle image object which has been descripted in the text before
http://worldwide.espacenet.com/publicationDetails/mosaics?CC=WO&NR=2009154492A2&KC=A2&FT=D&ND=3&date=20091223&DB=EPODOC&locale=en_EP
based by their demonstration
http://worldwide.espacenet.com/publicationDetails/mosaics?CC=DE&NR=20317795U1&KC=U1&FT=D&ND=3&date=20040226&DB=EPODOC&locale=en_EP
during a visit in Hassleben/Brandenburg/Germany in the month of December 2007
present Dr. Pavel Imris ,Dipl.-Ing Guenter Iwanek,Eng.Tiago Coelho,Technico Jorge Ferreira and I as project-initiator
With my kindliest regard
                                       CdL
p.s.:  as circuit
http://worldwide.espacenet.com/publicationDetails/mosaics?CC=DE&NR=29910512U1&KC=U1&FT=D&ND=3&date=19990812&DB=EPODOC&locale=en_EP
and here the Pavel Imris/Guenter Iwanek application work process description:
http://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=20317795U1&KC=U1&FT=D&ND=3&date=20040226&DB=EPODOC&locale=en_EP
with translation possibility
to see "Tabelle 1" go to "original document" page 4
p.s.II :
          1919 condenser motor
http://worldwide.espacenet.com/publicationDetails/mosaics?CC=GB&NR=157262A&KC=A&FT=D&ND=3&date=19220710&DB=EPODOC&locale=en_EP
description:
http://worldwide.espacenet.com/publicationDetails/description?CC=GB&NR=157262A&KC=A&FT=D&ND=3&date=19220710&DB=EPODOC&locale=en_EP
and
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19220710&CC=GB&NR=157263A&KC=A
